 Master switch red light
George Beck
Initially Posted - 09/30/2003 :  20:08:17  Show Profile
Just noticed the red indicator light on main electric panel switch went out this week. I'm sure I am not the first for this. Boat is 1982 Tall with original panel. Any input for replacement appreciated as this is not merely a bulb replacement.
Response Posted - 09/30/2003 :  20:45:41  Show Profile  Visit Leon Sisson's Homepage
George,
Re: "<i>...red indicator light on main electric panel switch went out ... input for replacement appreciated as this is not merely a bulb replacement.</i>"
There are now available LED pilot lights with the required current limiting circuitry built in. Look for the ones with the desired voltage specified on the package. They are available in a variety of shapes, colors, bezels, panel hole sizes (3mm to 1/2"), draw almost no current (0.020A or less is typical), are impervious to hostile environments, and last about forever.
RoofRoof
Response Posted - 10/01/2003 :  10:30:21  Show Profile
You can replace it with any LED that accepts 12 volts. I found my replacement at Radio Shack for a buck or 2. Simple installation: Pull out the old one and cut the wires. Push in the new one, and wire it exactly as the old. You can't screw up.
Sea Trac
Vanuatu
Response Posted - 10/01/2003 :  11:29:20  Show Profile
My master switch light is amber and very bright. I would prefer a softer red. Is it the bulb that is colored or the crystal?
J.B. Manley
Antares '85 FK/SR #4849
Grand Lake O' the Cherokees
36°29'58" -94°59'59"
Response Posted - 10/01/2003 :  13:34:18  Show Profile  Visit Frank Hopper's Homepage
Blue LEDs are all the rage, they did not exist until recently.
<img src="http://members.cox.net/fhopper/Catalina25/sigbow.jpg" border=0>Frank and Martha in Wichita KS. Lake Cheney
Sea Trac
Vanuatu
Response Posted - 10/01/2003 :  13:46:23  Show Profile
Blue LEDs are all the rage, they did not exist until recently.<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
Frank,
Am I safe in extrapolating that to mean that the crystals are clear<img src=icon_smile_question.gif border=0 align=middle>
J.B. Manley
Response Posted - 10/01/2003 :  14:56:33  Show Profile  Visit Frank Hopper's Homepage
Frank,
J.B. Manley
I think that choice would be yours to create the effect you want. The LEDs are being used for flashlight now...
http://www.ledlenser.com/v2-16.html
http://www.theledlight.com/infinity.html
http://www.ledsupply.com/kit001.html
ave you tried coloring your current lense to reduce the opacity?
Sea Trac
Vanuatu
Response Posted - 10/01/2003 :  15:05:30  Show Profile
Have you tried coloring your current lense to reduce the opacity?<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
No, I just started thinking about this. Suppose I could try red fingernail polish like I did on my galley lightbulb.
J.B. Manley
Response Posted - 10/01/2003 :  15:46:00  Show Profile  Visit Champipple's Homepage
J.B. Manley
Not really on topic but related....
We replaced all of our cabin lights about 4 years ago. The new lights... <img src="http://www.westmarine.com/images/full/11364_f.jpg" border=0>
I went to radio shack and picked up a two way toggle switch, cut a hole in the inside lining and installed a second red bulb. Now, when underway at night, I flip the switch to the left and its red and it doesn't interfere with my night vision. While at the dock or anchored, I flip the switch to the right and we have regular light.
<img src="http://www.flags.com/images/layout/category_images/t_3964.jpg" border=0>
Stu Jackson C34
Response Posted - 10/01/2003 :  20:16:56  Show Profile
Another option if you think the light is too bright is to put in a 24 volt lamp. It'll be visible, but less bright.
Stu
George Beck
Response Posted - 10/02/2003 :  10:53:46  Show Profile
Boy this posting sure took a 180 turn but thanks to those for the info on the LED indicator ligth. Maybe those other folks didnt understand the query.
Buzz Maring
Response Posted - 10/02/2003 :  11:19:39  Show Profile
<font color=blue>Boy this posting sure took a 180 turn but thanks to those for the info on the LED indicator ligth. Maybe those other folks didnt understand the query.</font id=blue>
Hi George,
Yep ... the topic did wander a bit ... still, there's some additional good information here.
I had a similar problem ... I found a 12-volt panel light at an auto parts store that fit the hole in the panel exactly ... it was only a couple of bucks, and it works great ... 'just had to remove the old one and solder the connections for the new one. BTW, the auto parts store had red, amber, and I think a couple other colors, too.
'Hope that helps ... good luck!
Buzz Maring
~~Freya~~
C-25 SK/SR #68
