 Feedback: Table supports from Catalina Direct
nate
Initially Posted - 01/15/2002 :  13:07:57  Show Profile
I was wondering if anyone has feedback regarding the clamps sold by Catalina Direct that secure the folding table to the bulkhead? I have a 1987 WK SR with trad inter. A couple times the table has popped out of the brackets leading to a mess on the cabin
RichardG
Response Posted - 01/15/2002 :  20:00:33  Show Profile
Under technical tips: "Not Yet" Bottom of table - Wobbly Table cure. A small turnbuckle is used with a quick pull pin. The turnbuckle is tightened by hand to hold the table down firmly in the side mounts, no wobble. To release, unscrew the turnbuckle a c
Bristle
Response Posted - 01/15/2002 :  20:34:46  Show Profile
I use a somewhat simpler solution: a piece of a cedar shingle used as a wedge between the edge of the table and the hull liner, pressed in from the top. Works fine.
Doug
Response Posted - 01/15/2002 :  20:55:59  Show Profile
I used Catalina Direct's table clamps on our C22. They went on easy and worked just fine.
Doug - #1913 Noeta
John G-
Response Posted - 01/15/2002 :  21:06:23  Show Profile  Visit John G-'s Homepage
<font face='Comic Sans MS'><font size=2>My solution is not as elegant as the turnbuckle under the table but works on the same principle. I have a 1” X 1½” piece of teak, the width of the table, bolted through the bulkhead that pivots down and locks with a
