On my new (to me)C25 I discovered that the area behind the screws that attach the "hold up" bracket for the forward hatch cover to the side of the hatch opening was cracked leaving a substantial void with nothing for the screws to bite into as well as a h
Sounds to me like Bill's syringe method might work best, so that the epoxy flows into the void--then re-drill. I'll also suggest that you remove the hatch (just a few screws) and do the repair upside-down.
Hi Ron, If I understand your post right, the crack and void are in the hull side of the hold up not the hatch side. If this is correct, I can tell you that Bill's suggestion is right on. I did that repair myself. Mix up about twice as much epoxy with f
