 Rigging stroud covers
Billyboy
Initially Posted - 12/06/2003 :  08:04:05  Show Profile
Hello Mates,
I'm looking for a source for plastic split stroud covers, maybe in a length greater than 6'. How about suggested diameter size too?
No marine/sail stores here...online source?
Thanks!
Bill Holcomb
Response Posted - 12/06/2003 :  08:41:34  Show Profile
Hey Billy,
Not sure about lengths longer than 6', but West Marine has 'em in shorter lengths. Online, catalog, or local store.
Response Posted - 12/06/2003 :  11:05:45  Show Profile
How about using a piece of 3/4" pvc pipe? Only takes a few moments to take a shroud off (one at a time of course) and slip it inside the pipe. Use pvc end caps, drill a hole in them for the shroud and make a slit to slip the cable in.
Response Posted - 12/06/2003 :  11:06:16  Show Profile
Response Posted - 12/06/2003 :  14:28:06  Show Profile
I've had two riggers warn me not to use the tight-fitting split shroud covers. (Actually, the first recommended that I remove the ones that were on the boat when we bought it.) Apparently in a salt water environment, they just trap and hold salt, dirt, and such. Unless you have meathooks a shroud is a pretty smooth surface that isn't going to chafe a jib during a tack. I don't know what the experts think of PVC rollers on the shrouds.
Response Posted - 12/06/2003 :  15:30:07  Show Profile
Dave - I don't think I qualify as an expert, but I have PVC shroud rollers on TSU - they definitely help the genoa come across when tacking.
Derek
Response Posted - 12/06/2003 :  16:04:24  Show Profile  Visit Frank Hopper's Homepage
<br />Dave - I don't think I qualify as an expert, but I have PVC shroud rollers on TSU - they definitely help the genoa come across when tacking.
Derek
I just have the roller caps above the turnbuckles, almost like spreader rollers
jwilliams
Response Posted - 12/06/2003 :  16:39:55  Show Profile
Bill Bilbrey,
I installed PVC rollers I made from hardware store stuff on the forward and lower shrouds to help my 150 get around. They work perfectly 5 years later, keep the sail clean and look neat. Paul has them on his forwards too.
They are easy to make and install. I think I used 8ft lengths of 3/4".
Jim Williams
Hey Jude C25fk 2958
SF Bay
Response Posted - 12/06/2003 :  18:35:35  Show Profile  Visit Leon Sisson's Homepage
I agree that shroud rollers are OK, but tight fitting sleeves on stainless steel rigging are an invitation to hidden corrosion.
MattL
Response Posted - 12/07/2003 :  08:56:43  Show Profile
I put rollers on mine after getting a jennie. Without them the tack always gets caught, kind of a pain in a race.
Response Posted - 12/09/2003 :  08:47:46  Show Profile  Visit Frank Hopper's Homepage
Here is a link to a new site that handles theese chafe wheels, I like them.
http://mauriprosailing.com/cgi-bin/merchant2/merchant.mv?Screen=PROD& Store_Code=MPS& Product_Code=HAR285& Category_Code=MIS
jheard
Response Posted - 12/09/2003 :  19:05:40  Show Profile
I have plastic split shroud covers in Newport Beach, CA. They seem to work to keep corrosion out. The upper shrouds get more rusty than the lower shrouds that are covered.
Response Posted - 12/09/2003 :  22:22:36  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jheard</i>
<br />I have plastic split shroud covers in Newport Beach, CA. They seem to work to keep corrosion out. The upper shrouds get more rusty than the lower shrouds that are covered.
I took mine off shortly after buying the boat--no telling how long they were there... What I found inside was ugly! No obvious corrosion, but lots of dirt and salt, which can't be good.
I routinely spray the lower 3-4' of my shrouds when I'm hosing down the boat after a sail on a breezy day. With the sleeves, it apparently doesn't do any good.
Edited by - Dave Bristle on 12/09/2003 22:25:02
