Catalina 25 swing keel 1986. There is a beam on the inside of the boat which transfers force down from the mast to the lower hull. I'm not sure what it's called but it has delaminated from the fiberglass on a boat which was donated to our club. There
That beam is called a compression post. I'm not sure what you mean by 'delaminated from the fiberglass', unless at some point it has been changed from it's original state. It should be an natural exposed piece of solid wood about 3" square. I would be su
Thanks Mark, I'll have to go look again. It seem as though someone had glassed in the compression post for some reason. I'll look for any evidence that it has moved.
Do you know where I might be able to get manuals and drawings of the boat?
BTW, on a 1980 Catalina 25, the compression post is NOT solid. If you take it out and look down the middle, hollow! It's actually built up out of 4 1-by pieces of teak.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> BTW, on a 1980 Catalina 25, the compression post is NOT solid. If you take it out and look down the middle, hollow! It's actually built up ou
