 Yamaha 9.9 photos on 250
sailgal
Initially Posted - 01/19/2004 :  13:09:26  Show Profile
Figured I start a new thread since the topic showed much discussion.
Ok this is my 2002 High Thrust 9.9 4 stroke. I measured the actual "wet" submerged portion of the engine while in the down position (of course) and came up with about 22 and 1/4 inches. With the engine up I layed a yard stick down length of engine,as shown in photo. Engine is said to be a 25" shaft length.
Here is a shot to show the close fit and how the tiller arm (which houses the throttle, foward and reverse lever)angles against the fuel locker.
This is a shot of the engine turned
and the other direction...tiller arm presents problem, so I flip it back to get the extra few degrees of turn radius, which as you see is not much, but just enough to get me through the prop wash before I gain enough momentum to back into my slip.
Overall, I'm very happy with the performance, just wish the tiller arm was set up differently. I did find out that if need be it could be removed from the engine, but the question would be...where to? Hope this helps answer any questions.
Suzie, Tropical Sleigh
WB #619 Sarasota FL.
frog0911
Response Posted - 01/19/2004 :  20:48:54  Show Profile
Suzie, thanks a lot, the pictures cover just about any question I could come up with.
zebra50
Response Posted - 01/20/2004 :  10:43:34  Show Profile
This raises a question that I have had for some time. When measuring the shaft of an OB motor, from where to where is it measured?
Response Posted - 01/20/2004 :  18:16:46  Show Profile
Jay,
Shaft length is the distance from where the motor mount bears (upper inside of motor mount) to the cavitation plate above the prop.
zebra50
Response Posted - 01/21/2004 :  14:53:34  Show Profile
Thanks Arlyn, I knew I could count on you or someone to have the answer. Now I can go measure my Nissan 8hp and figure out the shaft length.
Chip Hunt
Response Posted - 01/22/2004 :  22:09:50  Show Profile
i have the exact same motor. you will be pleased with it. the electric start is a fine feature.
