I am in the process of running my lines aft and need to decide which blocks to use at the base of the mast. I installed the CD mast base plate under the stock mast base. I bought one Big Bullet swivel block (the 2.25 in. seems fine too) to try and it seems pretty good (but what do I know?). Any thoughts would be appreciated.
Scott & Kelly Larson "Ahti" 1980 SK SR Southern Oregon
When routing my mast and boom control lines aft, I installed a variety of turning blocks at the mast base depending on line size and load. I usually prefer Harken blocks, but for the 3/8" halyards I chose Ronstan ball bearing series 30 as I recall because of their favorable SWL/$ ratio. For the lighter lines I went with Harken 22mm Micro and 1-1/8" Bullet. My deck organizers are the 1-1/2" Harkens. For clutches I have Spinlock XAS series. To cleat the smaller lines, I use Harken #423 series camcleats with fairleads.
I've put maybe 1,000nm on this setup so far, including ocean use and winds up to 2nd reef. So far the only failure has been a hairline crack in one of the clutch housings.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Captain B</i> <br />Frank, Do you have the link to the blocks you've got? The only ones I saw came with deck plates.Thanks! <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Bryan,
It looks like he used [url="http://garhauermarine.com/index.cfm"]Garhauer[/url] swivel shackle blocks and added the springs, which can be bought separately. The springs help in keeping the blocks and lines off of the deck.
Garhauer has a very limited web site. Most of what I have bought from them has come from phone conversations. 909-985-9993 You basicly have to tell the receptionist what you want and she will figure it out, mine have optional bearings and springs. The seris 25 items are a little large for our boats but OK, my cheek blocks on my boom are also G 25s
