Today I checked on my 84 C-25, which is on the hard here on Long Island.
I found that water is evident under the port settee. Prior to covering her with a blue tarp (the stern is the only open area) I removed water in this same location that the prior
Another possible culprit is the genoa track, which has gillions of thru-bolts, most of which come in behind the teak trim above the windows. I had seepage on the starboard side, so I removed the teak strip and had a friend hold each nut from below while
There are a zillion spots it could come in. It may not have been there at all and snuck in from aft since the boat on a trailer or jack stands isn't the same angle as when it is in the water. Beside what Dave said regarding the jib tracks, there is also
I rebed all the stancions and found a major leak under the chainplate that holds down the forestay (furler). Rebed everything. There was hardly any caulk under these spots.
This is mostly a repeat of a post which I made back in October. I had been plagued with leaks for a couple of years and chased around inspecting and rebedding fittings, mostly to no avail. Then I hit on a method of FINDING the leaks instead of guessing
