Hi If I have a lead keel, and always raise my motor out of the water when docked, do I need to install zincs on my wing keel? Nobody uses power on my dock as it is just a "summer slip" with only one or two 125 volt receptacles on it which are rarely used.
Edited to add that if you use your boat in salt water you should attach a zinc to your outboard's cavitation plate.
For fresh water use, another metal other than zinc is used for protection but I'm damned if I can remember for sure what it is, but I think it might be bare aluminum.
If your through hulls aren't bronze, your outboard isnt left in the water and you have no other metal objects in the water (NO) you dont need a thing. Why would you you have nothing to corrode.
Lets add a twist, how about WB boats in salt water? The line cable attaches to the center board with a small clevis pin. I use to use a zinc fish which I clipped to the metal cable and hung overboard (new own precaution) Now that the cable is line the only metal is that clip at the attachment point to the board under the boat. No way to clip the zinc to it. My thought on this is that electrolysis occurs when dissimilar metals are in contact with each other and stray current attacks. The clevis and pin are stainless, so I wonder.....(where a metal cable touches the clevis ball, clips and so on..well there I'd be more concerned) Food for thought....
Suzie, that's why you should have a zinc on your outboard if you use it in salt water since the dissimilar metals within your engine, as well as your lower unit will be in contact with each other and the salt water while you are running under power. Those hours add up.
I have a zinc on my Honda outboard, and even though it is only a year old with only two trips to salt water you can see some pitting on it already. When I had a Catalina 22 swing keel a lot of folks in their association used zinc fishes, or somehow bonded them to their cast iron swing keels. I only owned my C22 swing for a little over a year and didn't worry about having a zinc in fresh water
Frank, there's actually a small pocket which is built into the lower unit of my Johnson 9.9 which is tapped and threaded to accept a rectangular zinc. The zinc corrodes at a rate that shows it's working and I replace it annually.
I tossed an old zinc into the bilge of my fin keeler just in case standing water creates some kind of circuit with the keel bolts. I'm not an electrical engineer, but if the idea isn't too useful it at least didn't take much work...
