I was talking with a guy this weekend and he mentioned that using different types of batteries is not a good idea. I have a traditional (flooded) starting battery and a brand new 86amp hour gel that I purchased at WM. The o/b alternator charges the starting battery and I have a solar cell hooked up to the gel. I also have a battery isolator. Am I correct in assuming the battery isolator prevents discharge problems between the two batteries? Can anyone explain why different types of batteries should not be used together? Thanks!!
Whenever two batteries are connected in parallel to the same circuit, current will flow from the battery with the higher voltage to the battery with the lower voltage, until the two batteries equalize. This current flow does no useful work and results in partially discharging a battery that would otherwise be fully charged. If the two batteries are not identical in age, condition, type, and manufacturer, they may not equalize at exactly the same voltage, which will put a strain on the charging system, and could result in one or the other battery being overcharged.
Nate: I'm just studying the use of two batteries...but I think what you need it a "battery combiner". It is described on page 120 of the Don Casey book, "Sailboat Electrics Simplified", and also West Marine has a discussion in that regard on their web site and you can also "Google" or "Yahoo" the term "battery combiner" and get plenty of information about adding a second battery and dealing with charging both and protecting both batteries....Dan #727
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">two batteries are connected in parallel to the same circuit<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
With an Off/A/Both/B Switch, is switching to "Both" the only way two batteries can be connected in parallel to the same circuit (thus equalizing)?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">current will flow from the battery with the higher voltage to the battery with the lower voltage, until the two batteries equalize.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
How quickly does the equalization occur? Is it instantaneous or does it take some time (e.g. when switching from "Off" to "B", for a very short moment it is on "Both")?
Also, does a battery isolator make a parallel circuit (thus equalization) impossible?
