 Cetol Gloss Coat Drying
DanMcFadden
Initially Posted - 05/18/2004 :  08:27:17  Show Profile
I'm a fan of Cetol for the teak on my boat. I recently sanded the old poly finish from my tiller, and applied 3 coats of Cetol, using a nylon scrubby for a light rubdown between coats. It looked great, and felt completely dry (1 day between each coat). I then applied a top coat of Cetol Gloss. After several days for drying, the finish has a slight sticky or tacky feel. Augmenting drying with an electric space heater didn't help. Has anyone else had this problem? What's the fix? Regards, Dan McFadden on "Deo Gratias"
Response Posted - 05/18/2004 :  08:54:55  Show Profile
Hmmm...I've never used the Cetol gloss before, but I've never had a tacky feeling with the Cetol satin finish. Could it be humidity???
PZell
Response Posted - 05/18/2004 :  11:40:59  Show Profile
I had the same problem once with Armada which is similar to Cetol.
I think it was a combination of too thick a coat and the humidity.
RichardG
Response Posted - 05/18/2004 :  14:36:08  Show Profile
As a somewhat recent convert to Cetol, I've found that Cetol seems to take several weeks to really harden fully (where you can't indent it at all with a fingernail). Thus I had to be careful about banging something hard (e.g. metal block) on the new finish until it fully hardened. I don't know if this is what you are talking about. On mine, all tackiness was gone after about a day of drying.
