Does anyone know the designed angle of the transom to the waterline? I am designing a motor mount that will have angle correction for outboard biult in to the design, rather than having to shim the motor to get this relationship correct. Thanks!!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by lancej</i> <br />Does anyone know the designed angle of the transom to the waterline? I am designing a motor mount that will have angle correction for outboard biult in to the design, rather than having to shim the motor to get this relationship correct. Thanks!! <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Lance,
I think it is fairly close to straight up and down.
You shouldn't have to shim the motor to get the right trim angle, but simply make a trim adjustment on the outboard to get the proper angle.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Most outboards have this featur built into them<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Even my old 1.5 hp air-cooled Eska has this feature built in, however it can't be adjusted completely vertical because the overhang is a bit too severe on my dinghy (but close enough).
Yes, most outboards have this feature, but my Evinrude Yachtwin 8 will not adjust quite far enough, and has a 3-4 degree angle to the water with the stock motor mount. THis leads to ineffective propulsion, especially in reverse, and more cavitation than desirable. The other option is a new outboard (with electric start) but I have to convince my wife....
Regardless of engine Lance, the transom is pretty much vertical if the boat is floating on her lines. However, if everyone aboard is sitting at the extreme aft end of the cockpit........well, the transom will have a distinct aft rake.......
Yes the Transom angle is a constant here, I was just wondering if it was designed at perpendicular to waterline, which it looks at if it is. Many boats have a negative relief to them, but it is usually pronouced, like -10 degrees. The variable I think is the motor here, as apparently many motors can be adjusted for this, my particular motor will not allow for this amount of adjustment. I will design a motor bracket based on this configuration, which will put the motor back perpendicular to the waterline as it should be. Also I can design for more lift, which will allow me to get the prop further into the water.
