Four or five months ago I removed the stern railing on my '83 FK/TR C25 and had a local welder tig weld several spots on it which had either cracked or had come completely apart. Now every one of these welds is rusting.
How do I remove the rust, and prevent it from reappearing?
A. There's lots of metal cleaning&polishing compounds out there... Last time around I used Meguiar's fiberglass cleaner/wax (has a very mild abrasive) and it worked well. (I was waxing/cleaning the boat and decided to try it on the stainless).
Q... and prevent it from reappearing?
A. You won't. The heat from the welding process has removed some of the anti-corrosion alloying from the stainless steel. This side-effect of welding is difficult to avoid.. you gotta run really low heat. Keeping the area waxed may slow things down.
Try to remove all the rust and then apply Wichinox according to the directions. It probably won't be a permanent solution - but it will slow down the rust's return. Derek
Next time, you might look for a different welder. I had some stainless welded about two years ago, it has sat out in all conditions ever since - not a bit of rust. It is possible, if the welder knows what he's doing.
I'd be just a bit upset about it. Is it possible to talk to the guy and have him re-weld it correctly?
It's possible that the welder used the wrong wire in his weldments. Heat will displace some of the cromium in the stainless but can be offset with the appropriate wire that can augment the bright metal lost.
It's been some time since I welded stainless but Dave L. might jump in and clear up the problem. I'm not sure a solution is in the offing, short of rewelding with the right wire.
You need to go back to your welder and find out what filler wire he used when he TIG welded it. See if you can find out the exact rod he used by number. Stainless will be an E308, E316, E410 or E502, these are the most common stainless. If he tells you he used an E7010, E7014, E6011or E6010 or something like that he used a steel filler rod. If it is rusting that fast he probably used steel filler wire which is more common than stainless. If he did all you will be able to do is to grind it back out and either TIG or MIG it back with stainless wire. As a quick check you can get out a magnet and see if it likes the weld spots.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Keith D.</i> <br />...go back to your welder and find out what filler wire he used... E7010, E7014, E6011 or E6010...If it is rusting that fast he probably used steel filler wire... <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Any welder who would use carbon steel rod for welding a stainless steel part is either incompetant, totally clueless, or was deliberately negligent. If the magnet test reveals the welds to be carbon steel, I think the welder owes you a do-it-over and an apology.
