With the outboard at half throttle, my voltmeter shows 14.5 volts going into my battery. Is this normal? I would think that a couple of hours of this would boil off the electrolyte. What would cause this? BTW, my battery is fully charged at the time that I checked.
I'm not an outboard expert, but the first thing that comes to mind is a faulty voltage regulator on the outboard - it should sense the charge level of the battery and provide current accordingly. Secondly, just because it's at 14.5V doesn't (I think) mean it's overcharging ... if it's 0.002 amps at 14.5V it shouldn't hurt the battery.
My Honda 9.9 produces that kind of voltage but never more than an amp or two. At that rate it would take 230 hours to recharge my batteries. Most light outboards like the ones used by C25's have a small 12 volt output it is not the same as an output from an alternator which can be at many amps. Larger outboards have this higher output in order to recharge the starting battery.
My 2 stroke Johnson 9.9 Sailmaster likewise puts out 14.5 volts to the batteries but only at about 4 amps at the usual throttle speed. This is normally a good voltage to charge your system and at the low amperage it's unlikely that you will supply enough amp hours to cook your cells. Most small 2 stroke outboards don't have regulated alternators.
As the other responses have stated, 14.5 volts is normal. The amperage is the key as well as how far down the battery charge has been allowed to go.
But, the answer to whether the alternator can "boil" the electrolyte out is potentially yes.......especially if you are motoring for a considerable period of time and start with a fairly "fully charged" battery. I noticed that the electrolyte in my #1 battery was below the top of the plates after motoring for around 6 hours one nice summer day with no breeze.
I'll agree with the others that have answered -- 14.5 volts is normal and good. If you have an ammeter in your car, you will see about the same reading there. As your battery charges, it will tend to draw less current and "boiling off the electrolyte" should not occur.
