 New windex
SteveG
Initially Posted - 01/04/2005 :  09:56:45  Show Profile
Hi All,
I purchased a new windex, the old one was damaged when the mast was unstepped, and I don't know what angle the tabs need to be set to. Should it be 55, 60, or 65 degrees? I have a standard rig, fin keel with roller furling.
Steve Gravel
Portsmouth, RI
C25 - 'Lady Jane'
SR/FK
Response Posted - 01/04/2005 :  12:16:07  Show Profile  Visit Frank Hopper's Homepage
They are simply reference points. You will learn how high you point relative to them and they will serve their purpose. For what it is worth, we do not point very well so wider is probably better.
I solved the issue last year by mounting them facing the bow! Thsi year was better.
Edited by - Frank Hopper on 01/04/2005 12:16:59
tinob
Response Posted - 01/04/2005 :  14:09:40  Show Profile
Frank did you mean the V points to the stern? Cool. To do otherwise would give credence to every adjustment effected when thing alighted on them. They are only reference points as you indicated. Especially when an errant bolt from the blue adjusts them.
Val on the hard DAGNABIT
SteveG
Response Posted - 01/04/2005 :  14:26:13  Show Profile
I guess what I was looking for is a rule of thumb that could be used for all Catalina 25s.<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by fhopper@mac.com</i>
<br />I solved the issue last year by mounting them facing the bow...
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Oops! Thanks for the tip, I have no desire to climb the mast to fix that kind of problem!
Response Posted - 01/04/2005 :  15:02:18  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tinob</i>
<br />Frank did you mean the V points to the stern? Cool. To do otherwise would give credence to every adjustment effected when thing alighted on them. They are only reference points as you indicated. Especially when an errant bolt from the blue adjusts them.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
On my second day in the water last season, an overweight bird recalibrated my Windex to point at the moon then a month after I fixed that, a windstorm blew the tabs off. (I'll be following the advice of another sailor and put a dab of caulk on the new tabs)
Anyway, Steve, I think that setting the Windex at 60 degrees will likely do.
Edited by - dlucier on 01/04/2005 15:17:42
Response Posted - 01/05/2005 :  07:46:16  Show Profile  Visit Champipple's Homepage
I'm pretty sure I set mine at the widest setting listed on the back of the box. You can bend them, of course past that, but as mentioned earlier 60 or 70 degrees sounds about right.
stampeder
Response Posted - 01/25/2005 :  02:49:46  Show Profile
I bought my new windex at CD and followed the directions, setting the tabs at 65 degrees -- I found this to be a very good guide....but as noted, it will be a guide and not a rule.
Ed Montague
Response Posted - 01/26/2005 :  13:39:56  Show Profile
I put mine at a 90 degree angle, that way they are at a 45 degree angle from the center line of the boat which is about as close the the wind as this cruiser generally points the boat. This gives a good reference when beating to weather. It also works well when heading off the wind. The arrow pointing back alined with the tabs is a good down wind position, the arrow pointing any further back is less efficient for cruising. OK, did everybody hear? I said CRUISING!!! I will admit that I occassionaly point higher, but for that I watch the head sail telltails and do all the racing mode stuff. Furthermore, I can eye ball 90 degrees, I would need a protrator for 65.
