 marine head
capnron1207
Initially Posted - 04/24/2005 :  20:25:50  Show Profile
i just bought an 83 c25 w a marine head. i located a through the hull valve next to the holding tank but there is nothing attached to it.what is the purpose of this valve? shouldn't it have been attached to the head?
capnron
Response Posted - 04/24/2005 :  20:48:48  Show Profile  Visit Leon Sisson's Homepage
What size is the thru-hull? 3/4"? 1-1/2"? Was the holding tank factory installed, or retrofit? Where is all this stuff located in your boat? I get the impression plumbing varied depending on year and factory options, so it might be good to give us more specific details of what you can see for sure.
Response Posted - 04/24/2005 :  22:39:04  Show Profile  Visit Frank Hopper's Homepage
capnron1207
Response Posted - 04/25/2005 :  14:37:27  Show Profile
there are no pipes attached to the through hull valve!
Response Posted - 04/25/2005 :  14:41:56  Show Profile
Assuming that the water inlet valve for your marine head is still hooked up, I believe the isolated thru-hull valve near your holding tank was at one time probably hooked to a Y-valve for the purpose of overboard discharging the contents of the holding tank.
Edited by - dlucier on 04/25/2005 14:42:39
capnron1207
Response Posted - 04/26/2005 :  12:21:50  Show Profile
<br />Assuming that the water inlet valve for your marine head is still hooked up, I believe the isolated thru-hull valve near your holding tank was at one time probably hooked to a Y-valve for the purpose of overboard discharging the contents of the holding tank.
capnron1207
Response Posted - 04/26/2005 :  12:22:54  Show Profile
where should i look for the inlet valve?
Response Posted - 04/26/2005 :  12:58:16  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by capnron1207</i>
<br />where should i look for the inlet valve?
I believe the factory installed marine head inlet valvess are all located below the V-berth through the small access door.
Response Posted - 04/26/2005 :  15:02:21  Show Profile  Visit Frank Hopper's Homepage
The location in the diagram I provided has it under the v berth.
Response Posted - 04/26/2005 :  15:30:35  Show Profile
<br />The location in the diagram I provided has it under the v berth.
Did they put holding tanks in the V-berths?...My holding tank is under a seat in the main cabin.
jlguthri
Response Posted - 04/26/2005 :  18:56:17  Show Profile  Visit jlguthri's Homepage
fhopper, curious... those drawings I see on here from catalina, where did they come from? I have found some here and there, and they seem very helpful... is there a complete collection somewhere?
Response Posted - 04/26/2005 :  20:20:22  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jlguthri</i>
<br />fhopper, curious... those drawings I see on here from catalina, where did they come from? I have found some here and there, and they seem very helpful... is there a complete collection somewhere?
The brochure and manuals section of the home page. When I got my boat I printed out all of them as well as saving them to my computer.
thaind
Response Posted - 04/26/2005 :  21:11:52  Show Profile
Where is your holding tank? I have a 79 dinette model, and that is where the factory tank an to-hull was.
Response Posted - 04/27/2005 :  08:59:17  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by thaind</i>
<br />Where is your holding tank? I have a 79 dinette model, and that is where the factory tank an to-hull was.
On my 1980, the holding tank is under the forward dinette seat and the to-hull is under the V-berth.
Edited by - dlucier on 04/27/2005 09:00:21
Doug
Response Posted - 04/27/2005 :  09:42:34  Show Profile
My 1980 TRaditional has the holding tank under the port setee. In the V berth there is a water inlet (1") and a outlet (2"). The outlet is now disconnected and capped off as I removed the Y valve when it broke. Only use the holding tank now.
Response Posted - 04/28/2005 :  16:50:39  Show Profile  Visit Champipple's Homepage
It most likely is on the port side if you have the dinnette version. Whatever lazarette is close to the bulkhead.
Note - I still get confused between dinette and traditional... I have the darn booth at Mcdonalds in my cabin and that is where mine is located. To me that is traditional because traditionally its what I've always had....
