 New Sheaves "To Much Play" ?
roberoo
Initially Posted - 05/22/2005 :  22:33:10  Show Profile  Visit roberoo's Homepage
I put all new sheaves (Nylon Non-Bearing ones from CD)in this weekend. It looks as if there is about an 1/8th inch of play between sheaves and the aluminum separator. Is this too much play? And if so can I use washers to get rid of the play?
Oh yes this a wire to all rope conversion.
Bob Sirekis
"Wind Between The Sheets"
83 SR/FK #3551
Erie Basin marina D-19
Buffalo, New York
Response Posted - 05/22/2005 :  22:52:02  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by roberoo</i>
<br />I put all new sheaves (Nylon Non-Bearing ones from CD)in this weekend. It looks as if there is about an 1/8th inch of play between sheaves and the aluminum separator. Is this too much play? And if so can I use washers to get rid of the play?
Bob,
There are masthead divider plates made to go between the sheaves. These plates take up the space between the sheaves and also keep the lines separated and on the sheave.
My CD book lists them for $8.70 each. Depending on the space between the sheaves, you may need more than one.
roberoo
Response Posted - 05/23/2005 :  22:42:19  Show Profile  Visit roberoo's Homepage
Okay that makes sense. How much is too much play? Should there be any side to side movement?
Response Posted - 05/24/2005 :  10:10:20  Show Profile
The problem with having play between the sheaves is that the halyard might jump off the sheave and get jammed between them. When that happens, you can't get the sail up or down. Wire halyards are so thin that even a little bit of extra space can be a problem. Since you have changed to all-rope, I wouldn't think that 1/8" would be excessive. If you put a spacer in there to take up some of the room, the spacer should be at least the same diameter as the sheaves.
Edited by - Steve Milby on 05/24/2005 10:21:12
Response Posted - 05/25/2005 :  18:40:01  Show Profile
This picture shows the masthead divider plate.
Buzz Maring
Response Posted - 05/26/2005 :  08:40:32  Show Profile
<font color="blue">This picture shows the masthead divider plate. - Don</font id="blue">
Thanks for posting that photo Don ... it reminded me of a question I've been meaning to ask for a long time.
Why are there four sheaves in the masthead instead of two
I hope I'm not missing something obvious ...
edit: My boat has internal halyards ... I'm thinking that internal halyards require only two sheaves, while external halyards require four ... is that correct?
Edited by - Buzz Maring on 05/26/2005 09:32:26
Response Posted - 05/26/2005 :  09:42:43  Show Profile  Visit Frank Hopper's Homepage
yes
roberoo
Response Posted - 05/27/2005 :  00:46:18  Show Profile  Visit roberoo's Homepage
Okay here is what I ended up doing to be safe. I already had the single aluminum spacer. And I ordered a second spacer from CD (They're Great). Now I figure if for some reason I have to much play I can sandwich fender washers between the 2 aluminum spacers. But the second spacer should be enough.
Can't figure why there would be play in the first place but thius should work.
