 rigging Questions
clayC
Initially Posted - 05/25/2005 :  14:56:03  Show Profile
After 10 months of restoring this boat We are about ready to splash! (We still have a lot left to do but nothing we cant do in the slip) So Sunday my wife and I decided to rig it, see if we had all of the parts. We first tried the method decribed in the Catalina manuel "one crew pull on the forestay while the other one lifts". When I think back how it must have looked, my 100# wife pulling on the forestay, I am glad we were in the yard instead of the boat slip! So we got on line checked out Tech Tips, built an A frame and got it up. My first Question why do I have two forestays?
Next question is there any place I can find out the size and lenght of the running rigging.
Thanks again for all of the help I have recived since starting this project. Its looking pretty good, now all I have to do is learn how to sail it!
Clay C
Kamalla 1980 C25 SK/TR
Response Posted - 05/25/2005 :  16:04:35  Show Profile  Visit Champipple's Homepage
You should only have 1 forestay
2 upper shrouds that connect through the spreaders
4 lower shrouds - 2 forward and 2 aft
and one backstay
There are, however 2 pins on the masthead on the forward side, only the inner of the two pins should have a shroud attached.
Usually, if you bring the rigging into a shop, they will duplicate it.
If you have more than that, something is wrong or has been seriously modified. Just out of curiosity, which a-frame did you build - can you post the link.
dw
Buzz Maring
Response Posted - 05/25/2005 :  16:05:45  Show Profile
<font color="blue">Next question is there any place I can find out the size and lenght of the running rigging. - Clay</font id="blue">
Hi Clay,
Is this what you need? It is from the old version of the C-25 manual:
RIGGING SPECIFICATION SCHEDULE C-25
<b>STANDARD RIG</b>
NOTE - MAST EXTRUSION = 28' - 0" ------- BOOM EXTRUSION = 10' - 4"
Description ------ S.S. Wire Size ------ L = Length ------ No. Reqd
Main Halyard ------ 1/8" 7x19 ------ 27' - 8" ------ 1
Jib Halyard ------ 1/8" 7x19 ------ 29' - 2" ------ 1
Forestay ------ 3/16" 1x19 ------ 29' -10" ------ 1
Single Backstay ------ 3/16" 1x19 ------ 32' - 3" ------ 1
Split Backstay ------ 3/16" 1x19 ------ 26' - 4" ------ 1
Backstay Bridle ------ 3/16" 1x19 ------ 5' - 8 1/2" ------ 2
Forward Lowers ------ 5/32" 1x19 ------ 14' - 5" ------ 2
Aft Lowers ------ 5/32" 1x19 ------ 14' - 7 1/4" ------ 2
Upper Shrouds ------ 3/16" 1x19 ------ 28' - 5 3/4" ------ 2
L = Eye to Eye for halyards
L = Eye to end of the threads for shrouds and stays
<b>TALL RIG</b>
NOTE - MAST EXTRUSION = 30' - 0" ------ BOOM EXTRUSION = 10' - 4"
Forestay ------ 3/16" 1x19 ------ 31' -10" ------ 1
Single Backstay ------ 3/16" 1x19 ------ 33' - 11 1/4" ------ 1
Split Backstay ------ 3/16" 1x19 ------ 28' - 2" ------ 1
Backstay Bridle ------ 3/16" 1x19 ------ 5' - 8 1/2" ----- 2
Forward Lowers ------ 5/32" 1x19 ------ 15' - 5" ------ 2
Aft Lowers ------ 5/32" 1x19 ------ 15' - 6 1/4" ------ 2
Upper Shrouds ------ 3/16" 1x19 ------ 30' - 6 1/2" ------ 2
All dimensions are approximate and subject to change
Response Posted - 05/25/2005 :  16:59:56  Show Profile  Visit Leon Sisson's Homepage
Clay C,<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">My first Question why do I have two forestays?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">Are you <b><i>sure</i></b> you have two forestays? Or does one of them look suspiciously like a wire jib halyard? (Standing rigging is generally stiff 1x19 wire, where as wire halyards are more flexible, like 7x7 or 7x19.)
Gambit
Response Posted - 05/26/2005 :  11:54:17  Show Profile
I too have a dual forestay, and they are definitely forestays, not a halyard. My thought was that it was done in order to do a quick change of the jib. We are not rigged for a spinnaker. There are two halyards in addition to the main.
Response Posted - 05/26/2005 :  15:58:51  Show Profile  Visit Champipple's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Gambit</i>
<br />I too have a dual forestay, and they are definitely forestays, not a halyard. My thought was that it was done in order to do a quick change of the jib. We are not rigged for a spinnaker. There are two halyards in addition to the main.
Was your boat rigged when you got her? Is it possible the old owner gave you everything including old stays? I've never seen that on our boat... Not to say it doesn't exist.
dw
clayC
Response Posted - 05/26/2005 :  16:42:06  Show Profile
I have a couple of pics if I can rember how to load themhttp://im1.shutterfly.com/procserv/47b5db07b3127cce918435641d8000000010108BcMm7Jqzb0
clayC
Response Posted - 05/26/2005 :  16:50:50  Show Profile
maybe this will work betterhttp://im1.shutterfly.com/procserv/47b5db07b3127cce918435781d9c00000016108BcMm7Jqzb0
Buzz Maring
Response Posted - 05/26/2005 :  18:21:30  Show Profile
Seeing is believing ... that's the first double forestay I've seen on a C-25 ... hmmmmm
Gambit
Response Posted - 05/26/2005 :  18:32:54  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Duane Wolff</i>
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Gambit</i>
dw
Yes, she was rigged and on the water.
Response Posted - 05/26/2005 :  18:38:30  Show Profile  Visit Frank Hopper's Homepage
Hmm indeed, is that some sort of windlass hiding there as well?
clayC
Response Posted - 05/26/2005 :  18:46:44  Show Profile
Nope no windlass. So what do you all think? an quick sail change Idea. This boat is set up with a spinaker. there are two Halyards up front.
Clay C
pjeffarch
Response Posted - 05/27/2005 :  00:14:53  Show Profile
Clay - be careful about using the rigging chart from the manual - I believe those lengths are for the cable half of the halyards, and do not include the rope part. Is this right Buzz? I just bought a '79 C25 and it has the rope/cable halyard configuration.
Response Posted - 05/27/2005 :  07:42:25  Show Profile  Visit Champipple's Homepage
There's a lot going on there, but my guess would be for a second jib. Did the DPO race her? If he did, he probably used that configuration to abuse his foredeck guy and make sail changes on the fly.
Tack to one side, raise the new sail inside the old, and drop the old sail after the next tack. He probably could have gotten away cheaper refitting his old sails and going with a tuff luff.
http://www.sparcraft.com/uk/products/headstay_system/default.asp
dw
Buzz Maring
Response Posted - 05/27/2005 :  09:16:23  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by pjeffarch</i>
<br />Clay - be careful about using the rigging chart from the manual - I believe those lengths are for the cable half of the halyards, and do not include the rope part. Is this right Buzz? I just bought a '79 C25 and it has the rope/cable halyard configuration.
Good catch Paul ... I think you're right ... I still use the old halyards, too.
