 Companionway frame replacement?
samoore
Initially Posted - 04/16/2002 :  11:38:02  Show Profile
The rails that hold my companionway hatch have split. I need to replace them.
Where does one purchase these rails instead of having to find teak and have it milled?
Sam Moore
Sam Moore
859 806-0933
teamwike
Response Posted - 04/16/2002 :  13:41:28  Show Profile
Try www.catalinadirect.com
Max
Response Posted - 04/16/2002 :  14:20:03  Show Profile
Sam, when you say the rail has split - do you mean the thinner lip that hangs over the hatchboards? Depending on how bad the split is, you might be able to repair it using Resourcinol (sp?) glue and stainless brads. As teak is so oily, I poured acetone into the split before applying the glue.
Steve Madsen
#2428
OJ (Ode to Joy)
tinob
Response Posted - 04/16/2002 :  14:40:15  Show Profile
[quote]
Sam,
I bought mine from the Catalina Factory...$ 38.00 if I recall correctly. It seems that you're expected to remember to raise the sliding hatch when closing it the last few inches.[;-)] Sometimes I do and sometimes I replace the rails.
Val on the hard DAGNABIT
Val Bisagni
Rick Heaverly 86 C25 5382
Belize
Response Posted - 04/16/2002 :  17:26:37  Show Profile
I had to replace two pieces of teak around my companionway. I stopped at a local lumberyard that has teak and they used the old pieces as a template and cut new ones. Total cost $30. Catalina Direct could supply them but were not sure of the pattern since Catalina changed it a couple of times over the years.
Rick Heaverly
samoore
Response Posted - 04/18/2002 :  00:08:08  Show Profile
Thanks All - Found them at Catalina Direct.
Lowell was very helpful!
A little pricy but easier than having them cut.
Sam Moore
859 806-0933
