I have a chance to buy a bristol 1995 Catalina 250 ballast, 12V only, with the trailer, slip, all original manuals, no outside cushions, 9.9 Mariner that runs fine, wheel steering, no dings, dents, or scrapes, beautiful inside and out, nice sheets. I am a rookie as a sailor, though I have crewed on a 38 ft modified to 40 ft 1969 Pearson in the Gulf off Naples and Marco and as crew won in class and placed 2nd in 3 regattas in the past 3 years (Won 2, placed 1). This will be my starter as a skipper. It is a fresh water boat and is hauled out in the fall for storage. they are asking $14K for slip thru April 1,06, boat and trailer. I think it is a no brainer. Any help would be appreciated very much. I think I have already bought it. Thanks again, Tim
Buying 1st sailboat,'95 Catalina 250 ballast. Need help and info. My first sailboat.
I went thru this (also with a 95WB) not too long ago.
Check (actually touch and work) the: stove all the lights vhf radio am/fm radio porta potti or head battery depth/speed sounder battery charger look for evidence of water in the rear of the boat, around the battery and under rear cushions look for evidence of water in the setees and in the bow under the vberth look for broken wires in the shrouds/stays
if you plan on trailering, check the tires/trailer brakes/lights
Check to see if the stainless steel keel cable has been replaced. If not, you should contact Catalina and get the free Vectra line replacement before the cable snaps. (they were very nice about it)
I didn't have all these problems, but, I had enough of them. Some of them, like bad trailer brakes or tires, can add a lot to the cost of a boat. Water inside the boat, as in our case, doesn't mean the boat leaks. The water tank under the sink was leaking. I don't mean to scare you, once we got everything to our liking, we just love the boat. You will too!!!!
14k with the trailer and slip sounds like a good deal. I just bought a 2000 WK last fall. One recommendation that I would make is to have a survey done. A survey may sound like a bit of a hassle, but: 1. A survey will ensure that your (inexperienced) impression is confirmed which will make you comfortable with your investment, and... 2. The survey will tell you exactly what you need to do to address any problems. You do not want to discover any issues when you are out on the water. That approach is inconvenient and dangerous (maybe that should be the other way around).
The survey will not delay the sale (or sail) significantly, and any reasonable seller shouldn't hesitate to permit this as part of the deal. Generally you would agree on a price with the understanding that the deal is pending the survey. You might want to make it clear to the seller that you are only looking for major problems; you don't intend to use the survey as a way to re-open price negotiation. Any 10 y.o. boat is going to need some attention; the issue is avoiding something major that is not obvious to your untrained eye.
If you are interested, the Society for Accredited Marine Surveyors (SAMS) can be reached at 1-800-344-9077 (I still have it in my Palm Pilot from last fall). They will give you the names and numbers of accredited surveyors in your area. Then you can call them up and find some one who is (1) familiar with sail boats and (2) available.
Good luck. In my six weeks of sailing my boat I have found that the 250 is a GREAT boat.
I have had my 95 WB for four years now. Although I have had no problems that I didn't bring on myself, I would have a good look at ten year old sails, is there a second reef point installed on the main sail? The condition of the bottom, what series rudder is installed and which keel cable is installed. Any defects noted are worth a price reduction. As noted a survey is probably worth money invested. C250 WB #089 sailing on the Great Sacandaga Lake in upstate N.Y.
I recently took a rigging maintenance class from a local rigger and he said that standing rigging really needs to be carefully inspected annually after about 7-10 years for possible replacement needs.
Also you mention that the boat has wheel steering. I would want a surveyor to make sure there is no corrosion in the steering mechanism either. That 7-10 year timeframe applies to steering as well.
A survey to include your rigging and steering would be a prudent thing to do with a 10 year old boat.
If everything checks out - this is an awesome boat and the support through this association is stellar!!!
