 Wanted:Lower forward shrouds
georgiaboater
Initially Posted - 07/12/2005 :  23:48:36  Show Profile
I need one or two lower forward shrouds, preferably encased in the sheathing/tubing for my C 25 1978 standard rigging.....
(Do not necessarily need the turnbuckles)
to replace trashed shrouds (courtesy of tropical storm Cindy)
The only good out of all of this is that I subsequently pulled my boat the day before Dennis hit.
Marshall P
Response Posted - 07/13/2005 :  09:24:57  Show Profile
Try [url="http://www.catalinadirect.com/"]Catalina Direct[/url], they should have them already made up.
georgiaboater
Response Posted - 07/14/2005 :  21:28:33  Show Profile
Thanks Don.
The only problem is, CD wants $119.95 plus shiping for a set of two and I am certain that at least one can be obtained through our web site for considerably less than that...all I really need is one.
Gloss
Response Posted - 07/14/2005 :  22:04:05  Show Profile
catalina direct will sell you one if that's all you need. They are great folks to work with.
Tom Potter
Response Posted - 07/14/2005 :  22:52:27  Show Profile
I have a new 5/32, 13'6" long shroud if it will work.
georgiaboater
Response Posted - 07/14/2005 :  23:51:37  Show Profile
Tom
5/32 seems right.
I am in Atlanta and boat is safely inland in North Pensacola.
I'll call my friend who is storing the boat and get a measurement on the one good forward lower shroud.
Tom Potter
Response Posted - 07/17/2005 :  12:56:44  Show Profile
Here's a picture of the shroud. Its measures 5/32, and is 13' 5" long.
georgiaboater
Response Posted - 07/17/2005 :  18:38:31  Show Profile
Thanks for the pictures.
Will let you know as soon as possible.
Marshall
Response Posted - 07/21/2005 :  13:49:17  Show Profile  Visit Frank Hopper's Homepage
That shroud will not work. Cat 25 does not have shroud slots for the T-bolt you show.
Georgia, dude, if your shroud is dead due to some specific incident to that a particular shroud then buy a new one. Yes I have some old shrouds but I replaced them because they are old!!! Why would you want unsafe rigging? If you have simply discovered a bad shroud then all of your standing rigging is suspect and you should buy all new. Don't scrimp on standing rigging, someone could die.
Gloss
Response Posted - 07/21/2005 :  16:16:44  Show Profile
Once again, Frank is right
Call Catalina Direct and you will get a new shroud, or shrouds very quickly.
I have some old tall rig shrouds, but could not in good conscience give them away. I'm going to use them (and my old C22 shrouds) in my handrails when I rebuild my backyard deck
Get new ones, the mast you save could be your own
georgiaboater
Response Posted - 07/21/2005 :  21:30:08  Show Profile
Frank and Frank
Ok you guys are right.....my thought now is to go ahead and buy the matched set of forward lower shrouds from CD...besides, I want to start replacing all my turnbuckes with the newer "open " type anyway.
And Frank Hopper...since you are at Channey......I assume you know Ken Solo (did a lot of Sweet 16 sailing with him in that association up until a few years ago.....is he still around?
Response Posted - 07/22/2005 :  01:41:13  Show Profile  Visit Frank Hopper's Homepage
Ken is now a Capri 25 sailor, Sweet 16 sailor, Fireball sailor, and O'Day 25 sailor. At least that is what I am aware of. He is a character!
