 Hotter Plugs?
wmuchmore
Initially Posted - 07/27/2005 :  20:37:58  Show Profile
Greetings all,
Like many of us I guess, my outboard, a Johnson 9.9, gets very little high speed use. It runs at low speed just getting back and forth to the dock. Obviously this contributes to plug fouling, so I was wondering if it would be advisable to use a hotter range spark plug, assuming one is available. The Johnson manual calls for Champion QL77JC4, which I am using. Has anyone experimented with hotter plugs to reduce plug fouling?
Mike M, #2083, TRFK
Response Posted - 07/27/2005 :  22:50:26  Show Profile
How often are your spark plugs needing to be cleaned or otherwise fouling out?
Couple thoughts.
I've had better luck with NGK plugs in 2 strokes. Might consider going to a high-quality fully synthetic 2 stroke oil too.
Also doesn't hurt to take the boat on a little 'motoring' cruise now and then so you can work the engine a bit and burn off some carbon. Just pretend it's a Mac 26M.
thaind
Response Posted - 07/27/2005 :  23:08:44  Show Profile
Are your fouled plugs black or white? I would suggest next time you change one take it to an outboard mechanic.
Ben
Response Posted - 07/28/2005 :  07:17:47  Show Profile
Mike M,
I had the same problem with my Johnson 9.9 sailmaster. After I dropped the sails and as I was motoring into the channel (before I got to the no-wake zone) I would run the engine at full throttle, or close to it, until the dark exhaust (carbon) was blown out. That way I could be reasonably sure that the engine wouldn't die on my as I was slowly motoring to my slip.
Response Posted - 07/28/2005 :  09:33:40  Show Profile
My old 79' 9.9hp Johnson ran like a champ even though when I got it, it had the original 16 year old factory plugs in it!
wmuchmore
Response Posted - 07/28/2005 :  22:06:58  Show Profile
Thanks to all for the good comments and suggestions. As usual this forum is a great source of help and advice.
Mike M, 2083
