 Solar Fan's - Day/Night -vs- Day only
Tom Potter
Initially Posted - 08/04/2005 :  20:06:53  Show Profile
I've been looking at Solar Fans to mount on my front hatch and was wondering the +/-'s of the standard day only type -v- the Day/night type. Obviously the main difference of course is the D/N running at night.
Are there any other +/-'s worth noting?
Are they really worth having?
1997 250 TR WK (sold)
1984 O'Day 28 (sold)
1979 SISU 22
Bath, NC.
Response Posted - 08/04/2005 :  22:20:46  Show Profile
The key to reducing mildew and thereby the worst of the odors is running the fan at night in order to remove the humid air when it's cooling down and before it starts condensing on everything in the interior. That's the whole point of the day-night units. Circulating air during the day does nothing for that problem--the air is generally being heated in the boat and its relative humidity is dropping to a lower level than outside.
ddlyle
Response Posted - 08/04/2005 :  22:47:50  Show Profile  Visit ddlyle's Homepage
Yes, worth having!
Mine has a battery (or capacitor ?) that stores the solar charge and continues to run the fan at night or very cloudy days. It's been running for years. It's NOT noisy.
It is also easy to remove which I did for 4 or 5 months.
Just put it in the drawer so the sunlight wouldn't make it run.
So I'm sure the battery ran down in a few days.
But when I put it back on deck for duty it came back to life very nicely.
I had to spin the fan blade to get it running and it's been running ever since.
I think mine is a Nicro (?) something like that. The company makes "millions" of them.
Mine isn't fancy (plastic housing vs. stainless steel that you see on fancy boats).
But it works great.
And when I stepped on the plastic housing (rain shield?) and tried to glue it back on ...
Well, the company mailed me a new housing / rain shield free!!
Fine company, fine product.
I'd get another in a heartbeat.
Edited by - ddlyle on 08/04/2005 22:48:21
tmhansen
Response Posted - 08/05/2005 :  00:30:00  Show Profile  Visit tmhansen's Homepage
Yes they really do help. We also have the day and night version. In the winter it seems that it does not get quite enough sun in our side yard to run 24/7 but it still runs each day.
One night I could not sleep and the noise, although minor was an annoyance so I stuffed a sock in the vent to stop the motor. The next morning with all four of us sleeping on the boat it was much more damp in the boat than it had been. I was chastised by the Admiral and admonished to never stop the fan motor again.
mmac
Response Posted - 08/05/2005 :  01:10:49  Show Profile
I put a day-only solar vent on Mara about 16 years ago. It really helps keep the musty smell out of the boat. After the 11 days of continous rain we had earlier this year, I noticed it had stopped running. Little Sailkote and a couple of turns by hand, and it started humming away again. I'd say I've gotten my money's worth for this vent.
However to really keep the boat "dry", I bought a WM electric dehumidifier last year. Some guys leave an electric lamp on all the time to do the same thing.
Esteban
Response Posted - 08/05/2005 :  09:21:58  Show Profile
Id be interested to see where everyone is placing these solar vents. I too have a lot of interest in one but just can't see where to place it as our deck space is very limited.
Survey says?
Esteban
Gloss
Response Posted - 08/05/2005 :  14:06:15  Show Profile
I have the largest Nicro solar day/night vent, model 2000 or something like that. It's square, stainless steel, and has a way to close it off if the seas are high. It's mounted through the roof between the mast and the front plexiglass hatch. It doesn't catch the headsail.
Works great. I recommend it highly. Keeps funky smells way down.
Tom Potter
Response Posted - 08/05/2005 :  16:15:28  Show Profile
Looks like the day/night is the way to go. How about mounting areas? I'm thinking the forward hatch would be a good place. Any thoughts on the best place to mount it?
Gloss
Response Posted - 08/05/2005 :  18:28:08  Show Profile
The front Hatch on the 89 wing is plexiglass so I didn't want to weaken it in any way as sometimes I will step on it inadvertantly. Fortunately I haven't gone through it. that's why mine is roof mounted.
Bubba
Response Posted - 08/05/2005 :  21:04:00  Show Profile
I installed the Nicro Day/Night 2000 through the forward hatch of my WK. I bought the (accessory) spacer (black ring in the picture) because the hatch isn't very thick. I went with the white plastic to blend in with the deck. The plastic seemed as tough as the stainless steel when I looked at both in the store.
The boat spent last winter under a blue poly tarp and enough light came through to keep this thing running all the time. No mold/mildew - kept the cabin fresh. I highly recommend it.
mmac
Response Posted - 08/06/2005 :  00:55:34  Show Profile
Mine vent is in the forward hatch. At the time I was real reluctant to cut that big of a hole in the deck.
tmhansen
Response Posted - 08/06/2005 :  01:52:26  Show Profile  Visit tmhansen's Homepage
I thought it would be easier to replace a hatch than to fill a hole in the deck so I drilled a hole in the hatch.
existentialsailor
Response Posted - 08/06/2005 :  07:13:56  Show Profile
Mine is on the forward hatch (Capri). My slip neighbors is on the cabin top slighty forward of the mast on the port side (Catalina 25). I like his placement better because it is behind the rigging, but I simply don't have the room there.
Ben
Response Posted - 08/10/2005 :  07:18:30  Show Profile
Has anyone thought of putting the solar fan in one of the companionway boards? I know this is a bit unorthadox, and I don't know if the fan would even operate on its side, but I would rather cut a hole in a companionway board (or make a board with a hole in it) rather than put a hole through the forward hatch.
John P
Response Posted - 08/10/2005 :  07:45:39  Show Profile  Visit John P's Homepage
Interesting idea Ben, I too would feel better doing that. However, I want to replace my hatch with something to let light in, so I was already thinking of a new hatch, or at least putting in a "window' in the hatch. If I am doing all that, then a fan is right at home there as well. Still thinking on it though.
Response Posted - 08/10/2005 :  10:35:21  Show Profile  Visit Frank Hopper's Homepage
I have a friend with a Capri 22 with starboard crib boards, he put a fan in one of the crib boards, works fine.
John P
Response Posted - 08/11/2005 :  07:39:22  Show Profile  Visit John P's Homepage
It seems that since I read this, I now notice that almost every sailboat in my marina has some version of a Nicro fan installed. I seel them install through the deck and through a forward hatch. This is to be added to the "To Do" list.
Ericson33
Response Posted - 08/11/2005 :  15:53:40  Show Profile  Visit Ericson33's Homepage
Another Idea that I have come up with is I have a 5W solar panel that a 12 volt fan is attached to. The solar panel was put on top of the coach roof and hard wired to a switch. The solar vent was monted in the forward hatch. The solar panel has enough power to turn the fan pretty well So when I know I will be up at the club for a couple of days I just leave it running. Seems to move the air inside the cabin very well. The fan was bought at Walmart for 9.00 So if I burn it out I will just go get another one.
Bubba
Response Posted - 08/11/2005 :  20:04:02  Show Profile
Boat US has the Nicro day/night fans on sale right now in Maryland - maybe nationally?
