 Ventilation aft
Al
Initially Posted - 03/21/2005 :  00:15:02  Show Profile
Having installed the powered vent in the forward hatch, I needed to add some passive
vents aft. I wanted to keep the coaming clear so I chose the coaming pockets for the
intakes. I drilled through the forward side of the pocket, expecting an inch of space
before I came out through the inner liner. I was only off about 8"...!
Since the two holes were also misaligned a few inches, I used some flexible 4 1/2"
ducting to connect the two sides.
(I only used about half of what's shown in the picture). While I was at it, I also
added some window screen...
After more than a little massaging, I attached the topside grill, then went below
and stuffed a few inches of hose into the liner and screwed down the deck plate...
Then the same thing on the port side...
...which requires being a little more of a contortionist...!
But all's well that ends well, and I'm happy with the way the whole system worked out...
Al Maniccia
SeaWolf C250WK #698
Marina Del Rey, CA
Edited by - Al on 03/21/2005 11:29:48
Response Posted - 03/21/2005 :  07:51:05  Show Profile
Al, very well done ventilation design, installation and documentation.
Edited by - Arlyn Stewart on 03/21/2005 07:52:10
Northlander
Response Posted - 03/21/2005 :  13:41:30  Show Profile
Al,
I agree awith Arlyn. Great idea!
Chris
Tom Potter
Response Posted - 03/21/2005 :  14:32:53  Show Profile
Thats sharp... Like the screen idea.
welshoff
Response Posted - 03/21/2005 :  17:50:46  Show Profile
Does the vent hose run level or does it go up/down as it passes through. It appears by the photo it runs down as it passes through.
I like the idea and it looks well done. Up here in the NW I have concerns on potetial rain water entering the boat via the grill in the coming.
Al
Response Posted - 03/21/2005 :  19:54:16  Show Profile
Yes, the inside deck ring is about 2" lower than the topside grill. Although the drain holes in the pocket would keep the water level in the pocket below the level of the bottom of the grill, it is possible for rain to enter and flow down the hose.
If it were me and I was expecting rain, I'd screw the deck plate into the inside deck ring before I left the boat. The double-wall hose with sealed connections at both ends is very nearly waterproof, I would guess. So you would never get more than 2" of water in the blocked off hose, before it became self-draining. If the hose did leak, it would leak into the bilge, and not the aft berth.
I'd guess the chances are slim that you'd get much water through there, but then again, it may not be appropriate for rainy conditions.
I originally was going to put a "hump" in the hose (a caterpillar shape) to avoid that possibility, but the 4" hose is a little bulky for that in the 9" space you have to work with. Maybe you could do it with 3" hose.
welshoff
Response Posted - 03/22/2005 :  09:27:39  Show Profile
Thanks Al. It sounds like you put a lot of thought into your installation and it came out very clean and functional. Again, well done.
s3tbuell
Response Posted - 03/23/2005 :  15:39:29  Show Profile
That is a great idea...and the pics are wonderful...
My only concern would be for any type of offshore or heavy weather sailing, you now have a way for water to flood the boat.
I grew up sailing in the San Francisco area....maybe I am paraniod
