Went out to winterize Seatitude yesterday and took some pics of my mods for 2010 that I have completed. For 2010, I added a slide-out, electric pump out Yetti Cooler, new brass LED cabin lighting, new teak-drawered cabin table with extension, first aid kit, and a lifting Davits for the Nissan 9.8. For pics and descriptions go to http://seatitude.intuitwebsites.com/
I guess we'll all start posting here again since sailing season is over for many of us.
Excellent improvements !! I have to check out that Yetti Cooler when I get a chance. Headibg down to the boat to get an afternoon sail in with my spouse. Supposed to be about 54F and light winds 5-6mph.
Mike, nice mods. I was thinking about a motor mount. I have a Honda which weighs about 125lbs. Which mount did you get? 100 or 150, and 26 or 34 length? Do you have closer pic of how you mounted? Thanks, Steve A
Admire the quality and execution of your mods... thanks for sharing. Could you, whenever you get around to it, provide a little more detail... particularly
1) Does the drawer lid hinge open or lift off and is it strong enough, as table extension, to place food, dishes, etc. on it in open position? 2) Is the pin showing on left holding the slider platform in place... what type of slider hardware did you use... and how do you keep the cooler from sliding 3) Clever idea and good looking way to gain more counter space... 4) Like your curtain material and rails, any close-ups of the way you've fastened this?
<< Thank you very much.
<<The drawer lid is 3/16" ply-teak that slides on rails I installed inside the drawer - that way with the drawer fully extended I can slide it to and fro to get to things both at the front and at the rear inside the drawer and yes it is plenty sturdy to hold a bottle of wine and two glasses or whatever.
<< Yes, the pin is a stainless steel pin that holds the sliding platform both closed and in open position. I used stainless steel ball bearing drawer slides rated at 110 pounds which are mounted with stainless steel screws on the right side and bolts with fender washers on left side. The cooler weighs in at about 22 pounds empty, so full of water it would go well under the 110 pounds. The cooler is straped down to the platform using 1" nylon webing with buckles and stainless steel eye straps mounted to the platform.
<< Very easy mod - perhaps some fiddles would be nice, but for a 15-minute modification, it does come in handy to put our little TV or electric heater.
This was a previous owner install - I think he used white hard plastic tubing like the kind you can buy at home depot to hook your refigerator ice maker up to your water supply and cut it down as 1" spacers to place between the rails and the cabin wall. He then just sent screws through into the inside cabin liner - i'll get more pics next time I'm out. I don't care for the color so my wife is going to sew new ones over the winter.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by piseas</i> <br />Mike, nice mods. I was thinking about a motor mount. I have a Honda which weighs about 125lbs. Which mount did you get? 100 or 150, and 26 or 34 length? Do you have closer pic of how you mounted? Thanks, Steve A <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by britinusa</i> <br />Micheal, do you take the davit down when you put up your bimini?
Some serious steel there! Randy will be jealous.
Paul <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I keep the davits stowed under the v-berth - and just use it when I need to service the outboard. But it is easily removable because it comes in two main pieces - the bass pole, which you put in through the rail mount ring and down onto the ball. Then you put the upper part onto the base pole. I can have it down, packed up, and under the v-berth in about 3 minutes.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stu Jackson C34</i> <br />Those Garhauer lifts are great and a great price compared to anyone elses models. Nice work, Mike. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I can't imagine the competing lifts would be nearly this good in quality and worksmanship. When you consider they're at least $150 more, why even consider anything but the Garhauer? They are fantastic!
