I do not know if this is still in effect but soon after I bought my boat and going to West Marine on a frequent basis, one time I discussed with the sales people that I had a bumper that had loss air and it would not hold pressure when I pumped it up with an air pump - Did they have any recommendations other than buy a new one ? They indicated if it was a Taylor bumper, the Taylor bumpers had a lifetime warranty, so I should just bring it in and they would give me a replacement.
This particular bumper was one of those white decrepit looking ones after seeing many years of service. I brought it in and they did give me a free replacement. The warranty from Taylor may have changed thru the years and so if the needle valve is leaking, they may not offer a free replacement. But I believe that if it has a leak elsewhere, they may still honor a warranty free replacement. It's worth at least asking.
Otherwise, your suggestions is a great one and should really be added to the tech section. many would just throw away a bumper if it leaked. Only issue I would have is that the screw may scratch the side of the hull, however, it would appear that the use of weld-on as you recomended, above, would appear to solve that issue. Thanks for the suggestion !!
I have three Taylor Made fenders that leak. I contacted them and they said they would send replacement valves. That was about two weeks ago and they have not yet arrived.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by hewebb</i> <br />I have three Taylor Made fenders that leak. I contacted them and they said they would send replacement valves. That was about two weeks ago and they have not yet arrived.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">I'll be interested to hear how you replace them. BTW, I put a little WD40 or whatever lube I have around on the pumping "needle" before I stick it into the valve--can't say whether it really helps, but it makes sense to me. (Then again, I'm a $+!nkp*++er.)
Here are the instructions they sent, however they have not sent the valves nor answered my inquiry as to shipping date.
HullGard®, Big BÔ & Super GardÔ Valve Replacement Instructions Required Tools - Taylor Made Rubber Valve - Needle Nose or Long Nose Pliers - Hand Inflation Pump or Air Compressor - Inflation needle valve - Hair dryer (optional) - Lubricant - A non-petroleum based grease or non curing silicone works best. A liquid soap maybe substituted but a water resistant, longer lasting lubricant will help insure better, longer lasting seals.
Valve Removal Step 1 – Place the fender in direct sunlight to warm the vinyl to make it more pliable and generally easier to work with. A hair dryer can be used in the absence of sunlight or to speed up the warming process. Concentrate the heat at the valve area to warm a 3-4” diameter area surrounding the valve.
Step 2– Place one pliers jaw inside the center hole of the valve and tilt the pliers down to create a small gap between the rubber valve and surrounding valve opening.
Insert the opposite side pliers jaw in this opening and securely grip the valve. The valve should pull out of the fender with a slight tug. If the valve slips from the pliers, repeat the process until it pulls free.
Replacement Step 3- Lubricate the outside of the valve and push it into the valve opening. A lubricated valve can be inserted without the aid of any hand tools. If more force is needed, carefully push on the face of the valve with the tips of the pliers. Do not force the valve by exerting force inside the center opening of the valve as this could tear the rubber within the valve.
Inflation Step 4 – Lubricate the inflation needle and insert into the valve. Be sure the inflation needle extends deep enough into the valve to allow air to pass through it. Inflate the fender. The recommended maximum inflation pressure is 2 psi. A properly inflated fender will feel firm and still look cylindrical - no bulging side walls.
Checking the Valve for Leaks Step 5 – The valve area should be submerged under water to look for escaping air. Spraying a soapy water solution around the valve to check for air bubbles is also a good method of leak detection. If a leak is found, repeat the valve removal and installation process making sure ample grease was used. If the second attempt is unsuccessful then there is most likely a problem with the internal valve seat and the fender should be replaced.
The replacement valves from Taylor Made came in the mail yesterday. I plan to sail tomorrow and will bring one of the leaky ones home to do the valve replacement. They sent an extra one. Could be I might mess one up.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I hate to see"fender" degraded to "bumper". <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I agree, Call them by their proper name....Crash Stoppers or as my wife calls them, Those white rubber doohickey's
