 Bilge Pump Hose
jhorner
Initially Posted - 09/22/2014 :  16:47:32  Show Profile
Crawling around my Cat 25 I found the bilge pump hose going nowhere. The pump is functional but I don't know where the hose enters the bilge. Any drawings or answers out there?
Response Posted - 09/22/2014 :  17:34:50  Show Profile
Pull the cover under the quarterberth and you'll see it on the port side of he bilge near the centerline.
Response Posted - 09/22/2014 :  18:16:58  Show Profile
On my dinette style, the business end of the hose lies (and is strapped down) in the lowest part of the bilge, runs up under the galley drawers and into the fender locker (dumpster). That's where it connects to the manual bilge pump then the hose follows the inside of the port side dumpster through a loop out to a thru hull on the transom well above waterline. Not sure what's visible on the other cabin types as I can see my keel and keel bolts in the bilge viewing them through openings in the dinette seat pedestals.
Response Posted - 09/23/2014 :  05:05:01  Show Profile
My hose runs the same as Bruces does but we both have dinette interiors if it makes a difference.
jhorner
Response Posted - 09/24/2014 :  05:22:53  Show Profile
Thanks, everyone. Will check things out tomorrow. Fall has arrived in the South.
