Preparing to install a new switch panel and now am asking myself why they located the original below the bottom step. You literally have to get down on your knees and elbows to read the panel
Giving serious thought to relocating it to above the galley sink (same place it was on our 1981 C25.)
Anyone have a clue why Catalina moved the panel to such an unfriendly location???
My '90 has the panel in the usual location behind the galley sink. I've never heard of one under the steps although that's where my fuse panel and battery switch is.
Confetti has her switch panel beside the steps (but she has several things that are located differently than after things went into production....) The panel is pretty high up on the side of the galley however, so its really no problem, and in fact that makes it easier to reach the switches from the cockpit. I also located the solar panel charging bus switches there and the main battery switch there too.....
I never got around to adding a 110v system to the boat, but I would have put it over behind the sink to keep it away from rain/spray that can get things damp by the ladder.
Instead, I cut a wide door in the bulkhead behind the sink, and attached a storage area under the port cockpit seat. Its a very handy place for things......
When considering where to locate a replacement or supplemental switch panel, it is best to consider what benefits would be ideal to derive from a new location. Obviously, not having to have others or you (if sailing alone) have to get to a switch panel under the steps would be an advantage. But even better is to locate the new switch panel whereby you could switch on the nav lights and steaming lights by not having to leave the cockpit - A definite benefit if sailing alone.
That is why I located my new switch panel on the front face panel of the sink adjacent to the companionway. (My Cat 25 is also a 1989.) My Nav switch is located on top left of the panel and just below it is the steaming light switch. These are easily accessible from the cockpit.
Addl photos of the install are on my website and at bottom of switch panel opening web screen also click on wiring link). The most important criteria I had for the new switch panel (Mfr - BEP) for locating it below the sink was that the inside footprint of the panel (what goes behind the sink face panel) had clearance with the sink bowl. There is sufficient clearance with the switch panel I selected, but as an additional safeguard, I covered the sink bowl closest areas to the panel with thick rubber tape.
I see why skippers were complaining about things under the steps!!! Your ladder has its port side virtually up against the Galley cabinet! Another difference from old Confetti, since her ladder is obviously a lot more narrow. Confetti has several inches between the ladder and the side of the galley cabinet, and it is quite easy to see and operate the panel switches and battery switch from the cockpit or the cabin.
With your wider ladder (or maybe its a wider Galley Cabinet?), you have a good location to get to from the cockpit also.... I think we would end up potentially bumping the switches if on the front, but Grandsons can bump into anything anywhere! (at least mine can!)
As the panel face is vertical, I plan to cut a new opening above the ice box (see Craig's picture above). This will reduce the risk of damage if someone splashes water while using the galley sink.)
As I will need to extend wires to move the panel - this will be a 2016 project.
Yeah Larry, our serial numbers are only two apart!
Based on some of the replies, a few clarifications:
The bumping into the switches on the front panel of the sink is not a biggy. For one thing, that area getting in close to the sink is somewhat restricted by space and so not an area where you would really brush across. Also, the BEP 8 switch horizontal panel besides having a narrow footprint behind the panel, I also selected it because the switches are for the most part recessed from the front panel display - Switches not exactly flush w/panel face but close to it. Actually, if someone were to somehow brush past the panel like with kids, the tendency would be to shut off the switch versus turning it on. But there are no locks on any switch panel and so if a kid wanted to mess with a switch panel, then one on the front panel of the sink is certainly something that would probably attract kid's eyes/attention and fiddling with the switches is right at the height for little kids ! So - you have a good point especially regarding little fingers getting to the switches.
OJ - My switch panel also allows for backlighting of the labels.
First, separate from backlighting the labels and common to most panels, each switch will illuminate with a small LED to indicate if the switch is "on". Then for backlighting, if desired, a specific switch can be targeted to switch on all backlighting. I decided to hook up backlighting to only come on for all labels when the switch for cabin lighting is turned "on". My thought was that backlighting only really needed when in the cabin and it is getting a bit dark - So then it would be natural to first turn the cabin lighting switch to "on" if any cabin lights desired to be independently switched on. Once that switch is in the "on" position, then all switch labels are backlit. Your Blue Seas panel probably offers same options.
I mounted the same panel behind the sink, along with the master battery switch and the bilge pump switch. I'll be redoing the shore power next year so I made sure the new panel has room for the matching 120v panel.
I do have the faucet installed now and it doesn't interfere with the breaker panel at all.
Your point about the switches under the stairway is well taken. I reviewed several boats before settling on the 1986. Catalina moved the battery location from underneath the starboard settee to underneath the quarterberth. Since the batteries were under the quarterberth, I imagine there was a cost savings to install the switches closer to the batteries. Still, that was one of the factors I steered away from.
"Lady E" 1986 Catalina 25: Fin Keel, Standard Rig, Inboard M12 Diesel, Sail No. 5339 Sailing out of Norwalk Cove Marina, Connecticut
Behind the sink makes the entire dumpster part of the "electrical closet" and could cause issues with stored items. Under the steps reduced the cable run, contained the connectors and allows for adding busses in the areas around the back. I also moved some of the lighting circuits to a handier place like OJ did.
I'm considering moving some of the circuits to weatherproof switches that I can easily access from the cockpit. I often sail alone, and I often sail at night. Going inside the cabin to turn on the running lights or the steaming light seems foolish. I also have an external weather proof 12V outlet for use if the batteries fail on my spot light. I'd leave the A/B/OFF battery switch in the cabin so it won't be accessible to casual strangers walking around the dock and I can be sure all the DC power stays off. Further, I'm looking for a VHF radio that has the controls on the mic, which I would also locate someplace accessible in the cockpit. Funny, we've all gone to great lengths to relocate sheets and halyards to the cockpit. I think the same logic holds for the electronic controls.
As always, my free advice comes with a double your money back guarantee.
Craig, could you post a picture of your (galley) electric panels from the backside? I'd like to see exactly where/how Catalina positioned/mounted them.
Capt Sam, USCG Master Near Coastal Isle of Hope, GA. Charleston,SC. Lake Murray, SC. Aboard Bobbin - 1982 Standard Rig-Swing Keel #2963 Dinette Model "On a powerboat you are going somewhere....On a Sailboat you are Already There!" Capt Sam
I have several times thought about relocating my electrical panel, which is behind the sink with the battery switch under the steps. The way Larry has his above the drawers would be my choice as it is convenient, as Frank points out removes the dumpster as being an "electrically challenging" storage locker, and as I rarely use the sink. The one caveat would be to make a plastic cover to deflect water if it would drip down.
Obviously, when dealing with a 25 ft platform compromises are abound and I believe that the cost of manufacturing may be the reason that the electrical panel morphed between behind the galley sink and behind the steps. For me it always then becomes is the expense/effort really worth it. For now with this upgrade my mantra is "if it ain't broke, don't fix it" .
Peter Bigelow C-25 TR/FK #2092 Limerick Rowayton, Ct Port Captain: Rowayton/Norwalk/Darien CT
If locating under the sink, make sure you check the foot print of the ne switch panel as to how far it will protrude inside so it does not touch the sink bowl.. The BEP 8 switch switch panel I went with had about 3/8"+ clearance. Even so, I then used thick rubber tape applied to the sink bowl where the panel inner structure came closest to the bowl just to ensure there was no contact/potential to ground out.
FWIW, we ran a separate pair of power/ground wires to the VHF. Prior to that, the VHF was using a ground wire that was daisy chained to the cabin lights . . . if not others.
stink potter, thanks for pointing out the pics. I like the last two. now all I need is a cabinet maker and an electrician to re-run the wad of wires from the port cockpit storage area. anyone willing to trade canvas/sail repairs for cabinet or electrical work? I'm also a certified sailing instructor with ASA and US Sailing and will trade for lessons. boat is in slip in Stockton, CA.
Lynn Buchanan 1988 C25 SR/WK #5777 Sailynn Nevada City, CA
