Hello, I'm a new CP 25 owner, and am looking for some help from one of you successful class racers. I am looking for some photos or diagrams of how you CP 25ers typically run spin sheets and barber-hauls (some like to call tweekers) My boat came completely de-rigged, and no other CP 25s racing in area.
My boat has lots of blocks for the toe rail and a bunch of cam-cleats, etc on the cabin top. Trying to leverage prior experiences and not re-invent my rig. I have the foreguy and pole lift all set, and have extensive experience with symmetric spins, so no help needed there, just looking for the system most of you use with your sheets. (I'll be back for CP 25 trim tips in the near future)
BTW, with only 2-one hour sails ever on the boat, I entered the local frostbite series, and placed 4 of 8 and 4 of 9. (Frostbite is non-spin.) Although we raced one class, I beat all of the B & C class boats yesterday, including a couple J-70s (all on corrected time) This thing is pretty darn quick, at least in light air, and mine is a pretty beat up boat, but with really nice sails.
It would help if you update your Forum profile with your details. Things like where you are located and your boat year, etc.
There are several Capri-25s in Minnesota, our former Mainsheet Capri-25 is in Ohio, and there are a few Capri-25 at our club in Northern California. I don't own a Capri-25, but there are a few folks around.
Check out our Photo Gallery, there should be a few Capri-25 photos there.
Thanks, Russ
Russ, My profile is current, along with boat, and location. (I did lie about being 100yrs old).
So you're in Maryland. It's much easier to visit someone's boat than to rig it from photos, but you knew that. Let me check to see I can get you some help or find some photos.
I personally never rigged twings for my boat... I instead used blocks on the toe rail (outboard spin tracks). If I needed to choke off the spin, I slid the spin blocks up the track, but never further than the furthest forward spot on the track (right about even with the coach roof).
Oh, you wanna make the foreguy work better for you, instead of leading it to the middle of the foredeck, put a block at the foot of the mast to control it (then when you rock the spin port to starboard, you don't need to adjust the foreguy/top lift).
Up until about 15 knots true, no need to twing down (close the leach/choke).
Now if you are already familiar with sailing under symmetrical spin, you likely are more knowledgeable about trimming the spin than I.
Downwind the Capri likes you to sail as deep as you can. DDW, and slightly off DDW will be fastest, and you'll beat most of those crazy sprit boats, boat for boat... yep you heard me BOAT FOR BOAT.
Now, if you gotta reach fest, they are gonna EAT YOUR LUNCH. UPWIND, they will eat your lunch. You can prevent losing too much ground to them, if you stop trying to point with them, again upwind. I found ticking off about 2-3 degrees from say a J/24, or S2 7.9, B25, melges 24, or similar slightly faster boats, allowed you to make up for VMG loss, somewhat.
I also called twings/tweakers, barber-haulers, and I had an old salt correct me once that barber haulers are exclusively for hauling sheets/guys OUTWARD, as in you are downwind, need to ease the genoa sheet, a barber hauler, will PULL the sheet further out, opening the leach.
Here is a (rare) good spin trim picture... actually the pole could be higher
Here is a closer shot of the blocks on the outboard I used "like" twings... Yep the leeward side gets the bock slid back (and yes this is not slid back and its the leeward side, but you get the gist)... It's slow but it works.
Kudos for Russ for reminding me that this forum is sometimes actually visited by Capri owners.
WYC folks are your Capri 25 experts. Worthwhile to join their list server too.
I've backed off of the Capri 25/Cat 25 forum, because I'm now on my second year with an S2 7.9. The S2 is not a "better" boat, just different. I'm still learning to appreciate the "fluffy/comfy" aspects of the boat. This boat doesn't heat up like the Capri 25 did, and in a lot of ways isn't as much fun to drive. It IS however, significantly faster on all OTHER points of sail, except downwind. The Capri 25 is by far and away the most interesting boat downwind I've been on (and yes I've been on the Melges 24, and B25s now). I truly believe DDW, the Capri 25 can beat them ALL boat for boat. Until its time to plane... YES I had the Capri 25 up to 10 knots under spin, and it gets tricky to hold it under the spin. They don't call it a broach coach for nothing.
If you have specific questions feel free to email me shnool at yahoo
