Certainly not the cockpit seats or sole--they are meant to drain to the transom. (Although swing keel owners have found that it doesn't always work with the keel down, which makes its CG is further forward). What are you trying to determine? Do you have a carpenter's level? That would show what's level to the true waterline.
When I had my C250, I determined that the cabin sole was level with the exterior waterline stripe when measured in the cabin on the centerline right at the sink cabinet.
I determined this while on the hard using a laser level. I adjusted the boat stands so that the waterline stripe was perfectly level, then verified that the cabin sole was level.
As I've mentioned in other threads, it is important to store the boat perfectly level to ensure proper drainage past both the foredeck and companionway hatches. This is important in the slip as well as on the hard.
Rick, exactly the info I am looking for. Thank you so much.
Dave, I'd like to adjust the rig while on the trailer. If I can make the boat level, per Rick's info, I can use the main halyard to get a datum for mast rake and start working from there. The PO cranked down the FF2 forestay so tightly that the mast bent forward from the spreaders up. I didn't notice it until I was working on dropping the rig. So, that's what I'm up to... in addition to trying to store it level per Rick's advice.
Richard: Sorry, I didn't notice you were posting in the C-250 forum--my statement about the keel refers to the C-25 swing keel, not the C-250 centerboard. I need to be more observant.
quote: I adjusted the boat stands so that the waterline stripe was perfectly level
Going by the boot stripe could be misleading. Many will look at their boat sitting in a slip and the boat may appear nose down or stern down. This is caused by the boot stripe not being level with the "true" waterline causing an optical illusion. I don't think Catalina got the boot stripes dead on even with the true waterline. You can get the boat close to level on the hard to adjust the mast but not perfect. You really have to sail the boat to fine tune the mast. Take it out and see what kind of feedback the helm gives you then adjust the mast to compensate. You may have to do this a few times to get the helm feeling just right.
Those who are familiar with this boat realize that when the boat is level, the companionway hatch slants a couple of degrees aft (draining into cockpit) and the gutters around the forepeak hatch slant a couple degrees forward (draining into anchor locker). True level occurs only when both of these hatches drain properly. Failure to do so will result in one or the other hatch leaking into the cabin.
In my boat, the waterline stripe was true, providing proper drainage of both hatches.
The wing keel models are known to ride bow high, leading to a leaking forepeak hatch unless something is done to bring the boat level. I chose to add ballast to accomplish this. There are many posts on this topic here, from me and others.
The water ballast model is believed to ride differently due to different weight distribution.
Note also that Catalina modified the wing keel at least once during the production run. Different wing keels could cause the boat to float differenly.
