The original blocks used for the jib sheets on my 04' 250 were too tall and would roll the sheet over the three wraps on the winch and get in a bind. I replaced them with the low lead car from Catalina Direct and now the sheet approaches the winch from below the wraps. They work great and I would recommend them to anyone with the same problem. They easily slide on the 1" track as a replacements. Something simple but with a positive impact on the sailing.
Before approach with the angle too high
After approach from below the wrap
Factory Tall Block
Replacement Low Lead Car
Regards, John Westlawn Institute graduate Yacht Design and Naval Architecture 04 Catalina 250 WK Standard rig w/wheel steering Yanmar 9hp diesel
Wow! Maybe I'm Superman or something but I never use my winches (especially with 3 wraps) to set my jib sheets. I just tug on them and set them in the cam cleat to keep them taught. Now if I had a 30 or 35 footer then yes I'd winch the jib sheets, but a 25' with a 135 genny, not so much. Maybe in a gale!?!?
Bruce, you bring up an excellent point, but my 250 doesn't have a single clam cleat on it from the factory. I have been trying to use it the way it came. I though that I would try this first.
Maybe I need to add some clam cleats? That does seem to be a logical observation. Thanks for the input. I have looked for examples and haven't found many with the cleat to determine the optimum location on a 250.
First, Bruce is Superman, at least most people think so.
Second, I have a C250 with the same problem with winch wrap. I took another approach and mounted a fairlead and cam cleat aft of the jib track. It's been a few years, but here's some links with parts that look right (check the sizes).
As side benefit, you can also put the jib sheet in the cam cleat when you tighten the main halyard.
FWIW, my C250 came with the low profile cars that you converted to. Even my C34 has the low profile ones (though bigger, obviously).
Those high profile ones that you show look like real toe-stubbers and trip-overs.
Another thing about Super-Bruce... He has a C-25 (used to be mine) where the sheet turns on a low block on the side-deck (which the 250 doesn't have) and leads upward to the winch on the coaming. Different geometry (if he used it). I have to wonder whether his cam cleats get locked on the sheets in stiff breezes, without the winches to ease most of the pressure... That can be a lot of stress on a lonely cam cleat. (If he's using the ones I put on, they're positioned to take the sheet as it comes off the winch and is hooked under one horn of the original horn cleat to hold it down in the cam--an alternative to risers for the cams but not obvious to successor owners.)
Thanks everyone...it is just something to consider. Sailed in 20 - 28 knots the other day without an issue. Sure was nice. FYI, I use one wrap up to 10, 2 wraps to 20 and 3 above that. If I need the winch for a halyard, I put it on a tack with the appropriate sheet loose. Basic stuff.
Hey, Bruce, what a surprise that you have no difficulty trimming the jib in a blow on Long Island Sound while not using the winch with 2 or 3 wraps!
One wrap seems to reduce the force 2x that is needed to haul in the line under tension, and 2 or 3 wraps seem to reduce the force by about 4x and maybe 8x, respectively. I cannot imagine how you can release the sheet from a cam cleat and then hold onto it when the wind is 15-20 kt! I believe that my life and the safety of my crew depend on the use of the winches to trim the jib, since the force of the jib clew pulling the sheet is immense and seems to be many hundreds of pounds.
You must be really strong, indeed!
JohnP 1978 C25 SR/FK "Gypsy" Mill Creek off the Magothy River, Chesapeake Bay Port Captain, northern Chesapeake Bay
John, lucky I guess. I rarely sail in 20s, not fun. I take a wrap on the cleats, then pass the sheets through the cam cleats. That reduces the stresses a lot. But mostly muscle.
My 135% genoa on my tall rig is way bigger than my kite I use to pull me across water and snow and take me through the air with no problem (kite boarding). I do not feel those forces would be manageable without a big harness attached to me. I know a winch is necessary on my boat to manage these forces. I am no slouch in the strength department either. Lets just say sailing is the easiest activity that I participate in out of many. I like the low lead car solution and think that will be on my short list as my wife is usually the one trimming the big sail when tacking. Thanks for the info. Glad there is a solution other than bigger winches as I like my larger sheets for easy handling. We often sail in 15-20 knot wind up here.
1998 250 WK/TR #355 "Trail Break" Lake Tahoe California
FYI. The one WK 727 purchased have a 2,000# working load and the less expensive ones are 1500#. Cam cleats rated at 300# might be a bit weak for a big genoa so I am not sure that is a good alternative.
