Call me a complete cheapskate but I recently replaced my rigging. I’m going to measure up my old lifelines against my upper shrouds. Maybe they’ll fit.
I got some foam pool noodles last year for my stern pulpit that softened the railings up (when I bang my head). I can string up several noodles to cover the wire without encapsulating it in plastic. Anybody suggest another type of foam covering?
I don't understand why you would cover them. I was thinking of stripping the vinyl off of mine since that is what causes the rust and corrosion. Put lifeline cushions on the gates to finish the look and your good to go.
I replaced my lifelines two years ago. The "originals" (I presume they were) had vinyl covering. When I replace them I only put vinyl where they open and I lean so now I can inspect most very easily. When I removed the vinyl from the old ones it was very revealing -- the wire was rusted and clearly needed to be replaced. The cost to replace, I believed, was well worth it for the safety. I question how much could/would be saved by repurposing shrouds as the swaging can be tricky and costly.
Peter Bigelow C-25 TR/FK #2092 Limerick Rowayton, Ct Port Captain: Rowayton/Norwalk/Darien CT
CS Johnson sells hand crimp hardware for lifelines. Your shrouds have the turnbuckles so all you would have to buy is 2 gate hinges and 2 pelican hooks and the crimp tool. If you don't mind the lifelines going slack when you open the gate then you don't need the hinges.
I considered getting the type without the vinyl coating, but chose otherwise for aesthetic reasons. I got about 37 years out of the old ones, and if these last half that long, I should be good. I also reasoned (wisely?) that any failure will probably be at the terminals, which are uncovered either way.
There's always that rubber dip stuff for treating the ends of your plier handles and screwdrivers. There's probably a way to paint that stuff on if you really want to coat the wires. I seem to recall that you can purchase plastic wire coverings from an electrical supply house. And there's the corkscrew cable management cable dressings for AV equipment, usually white that wraps around a bundle of video and audio cables to keep the chaos down in your man-cave TV wiring. White electrical tape spiraled over the cables would probably do until the adhesive dried out. Or you could keep them bare wire...
