 How to lower/remove the swing keel
myersge1
Initially Posted - 03/19/2018 :  18:57:36  Show Profile
I'm going to haul out next month and may have to disconnect/remove the swing keel for repair depending on how it looks once I get it out of the water. Has anyone come up with a fixture/carriage that works with a floor jack or is there another way to safely remove and reinstall the swing keel?
Response Posted - 03/20/2018 :  04:19:07  Show Profile
Is it going to be on a trailer or stands?
myersge1
Response Posted - 03/20/2018 :  05:31:33  Show Profile
Not sure yet. I have a trailer but I want to do the work on stands. I'm waiting to hear back from the Marina on their recommendation. I know people here have pulled their boat out of the lake on their trailer and then transitioned to stands by either a lift and straps or by placing stands as the trailer is pulled forward. So to answer your question, stands.
Response Posted - 03/20/2018 :  13:30:05  Show Profile
I recalled discussions on using threaded rods to lower the keel, and tried Searching on "swing keel lower rod" including archived posts... Lots of discussions! At the end of this one, Leon Sisson (a long-time C-25 guru here) also mentions blocking up the trailer and removing the axles to be able to lower and access the keel--an interesting option.
odonnellryanc
Response Posted - 03/21/2018 :  13:00:08  Show Profile
I'm in the same situation as you, I'm going to have the yard price me on the heavy work: removing and reattaching the keel. Hopefully not more than a few hundred dollars, we'll see. If it's a lot I'm going to have to figure out some kind of rig... I don't have a trailer.
Threaded rods seem to be a common solution.
I know my PO tried to remove the keel himself to do maintenance and quickly had some kind of issue where the yard had to help him put it back on. Hopefully no damage caused by that attempt, from what I can see so far the trunk and keel seem fine.
jduck00
Response Posted - 03/22/2018 :  16:56:40  Show Profile
I've done it several ways, none is fun. I've lowered the boat onto the keel, I've lowered it with all thread, and I've lowered it with a jack.
If you are removing the keel completely for repair, here is what I did. I built a cradle out of 4x4's that would hold the keel and could be picked up with a fork lift. I had the boat lifted with a crane and set over the cradle. Once it was in the cradle, I pulled the bolts and left the keel in the cradle and had the crane set the boat back on the trailer. Made it real easy for moving around.
As far as maintenance goes, I prefer a jack while the boat is on stands. I don't have enough clearance on my trailer to do anything so I do my maintenance on stands. I block up under the front of the keel so it can only come down so far and then use a jack to get it up. I've got some pictures of my setup. I'll dig them out and post them. Never had any luck with all thread. It seems to bend and never go back up straight for me.
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
jduck00
Response Posted - 03/22/2018 :  17:26:22  Show Profile
Here is the blocking I use while its on stands. Works pretty well over all. Its a lot easier to get back up with two people.
Here is pic of the keel in its work cradle.
In its cradle ready to go back on. This is the only time all thread has been useful for me.
BTW, the keel was finished in stages. Eventually it was fully wrapped in fiberglass and painted. These are some of the in between pics.
Hit me up if you want to talk through the different options.
Jeremy Duck
The Lucky Duck
Frank Law
Response Posted - 03/22/2018 :  19:38:39  Show Profile
I used the all thread method twice . I built a framework that guided and held the keel safe , you could use Jacks to lower the keel still using a frame work to prevent the keel from falling over . I don't have any pictures .
Frank Law
Response Posted - 03/22/2018 :  19:40:26  Show Profile
I forgot to mention the boat was on jack stands
myersge1
Response Posted - 03/27/2018 :  19:20:38  Show Profile
Thanks for all the ideas. I love the pictures. I have an idea for a wooden frame much like jduck00's that will work with a floor jack. My plan was to get the boat on stands with the keel barely off the ground, lower the rear of the keel via the cable so half of the weight is resting on frame on the ground, jack the front of the frame up to meet the front of the keel, unbolt the keel, and then lower the front of the keel to the ground. It's a 2000 lb floor jack so it should be sufficient.
jduck00, how did you manipulate the heavy keel to get it cleaned up, wrapped in fiberglass, and painted? I plan on just cleaning and painting but curious how you flipped it over to do both sides?
jduck00
Response Posted - 03/28/2018 :  05:27:46  Show Profile
I did most of it sitting in the cradle. I got pretty much every thing except the leading edge done on the cradle, and finished up when I had the boat on stands. I didn't have any way of moving it once it was in the back of the truck, just had to work around the cradle the best I could.
I did have it sand blasted and primed before I started. The fellow I had do that lifted it out of the cradle with a set of straps and fork lift.
Jeremy Duck
The Lucky Duck
sethp001
Mainsheet C-25 Tech Editor
Response Posted - 04/09/2018 :  15:34:09  Show Profile
Wow, Jeremy, that looks great! Can you discern any difference in performance?
Seth
"Nomad" 1980 Prindle 16
