 Inspection port size
stang9150
Initially Posted - 04/22/2018 :  12:07:36  Show Profile
I need to replace the upper rudder hardware. They use to have the kit on Catalina direct with the inspection port. It appears that is gone I can not find it. Was it a 4 inch port?
Response Posted - 04/22/2018 :  17:37:03  Show Profile
I used a 4" port. They can be had at any marine store or off the internet. Just remember to measure down the transom to the gudgeon then transfer the measurement to the interior.https://www.westmarine.com/buy/west-marine--4-screw-in-deck-plate--11743002?recordNum=1
Edited by - islander on 04/22/2018 18:00:10
JB
Response Posted - 04/23/2018 :  08:54:05  Show Profile
The hole saw that came with the kit had a short centering drill bit. There isn't much gap between the between inner and outer hull and a normal bit is too long.
1988 C25 Wing Keel Std Rig Tohatsu 9.9 Tiller Steering and 2003 C250 Wing Keel Std Rig Inboard Diesel Wheel Steering
