 Holding Tank Capacity
Wye Knot
Initially Posted - 04/24/2018 :  09:49:18  Show Profile
Good Day,
I am still i discovery mode on the boat. I have searched the Catalina owners' manual and cannot find the capacity of the holding tank. The previous owner believes it is 11 gallons and I found a forum posting on the net which states that it is 17 gallons. The post stated that the tank was a Ronco Plastic Model B123. I would appreciate additional input so as to manage the holding tank level and avoid an unpleasant learning experience.
Thank you.
Bill
Russ.Johnson
Commodore
Response Posted - 04/26/2018 :  18:46:02  Show Profile
Bill,
The C250 Marine Head was an option that not many owners bought.
It's not that we are ignoring you, it's just that we don't know the answer.
I'm not sure, but the marine head might have only been an option for the Winged-Keel and not available for the Water-Ballast model.
Because the holding tank is near the transom, it might also interfere with the wheel steering option.
Can you please confirm you have a winged-keel with tiller steering?
Thanks, Russ
Russ Johnson
2005 C250WB Hull 793
Response Posted - 04/26/2018 :  21:01:56  Show Profile
I had a wing keel version that came out of the factory with a marine head/holding tank and a tiller. I am told that it was 13 gal capacity. A later owner converted to wheel steering and had to reduce holding tank to 6 gallons due to the space requirements.
Bottom line: It can be almost anything, since this is a non-standard option that is often installed or modified by the dealer instead of the factory. I think the best way is to measure capacity by adding a known quantity of water and getting back there with a flashlight to observe the level. A good rinse would never be a bad thing anyway.
If I were installing one again, I'd get an upright tank and locate it right behind the wet locker. That long hose run back to the aft lazarette is horrible, with a dead volume of a couple gallons, and an long uphill slope that fails to drain into the tank. As a result, it is impossible to do a good purge of the line, and stuff invariably permeates the hose.
Rick S., Swarthmore, PA
PO of Take Five, 1998 Catalina 250WK #348 (relocated to Baltimore's Inner Harbor)
New owner of 2001 Catalina 34MkII #1535 Breakin' Away (at Rock Hall Landing Marina)
Wye Knot
Response Posted - 04/28/2018 :  04:45:44  Show Profile
Hi Russ, the boat is a wing keel with Edson Steering. Thanks, Bill
Originally posted by Russ.Johnson
Bill,
Thanks, Russ
Wye Knot
Response Posted - 04/28/2018 :  04:50:14  Show Profile
Thank you Rick. I see the hoses going aft can be a problem and hold waste residual.
