The basic idea is make sure the uppers and forestay and backstay are hand tight so the mast is plum. To do this without a Loose Gauge I then hand tighten the lowers, then back off two turns. Go sailing in your comfortable wind speed and check shrouds on port and starboard tacks for equal slack tension. Go sailing again and check for lee or weather helm. Adjust the forestay.
Lynn Buchanan 1988 C25 SR/WK #5777 Sailynn Nevada City, CA
When the boat is at the dock the upper shrouds, lower shrouds forestay and backstay should seem tight. The mast should be centered and plumb straight up and down. There should be no play in the rigging, meaning the stays and shrouds should feel firm. When plucked they should all vibrate smartly.
When the boat is sailing and on a heel, however, the leeward shrouds will get loose and may even sag. This is normal. When on the opposite tack, your leeward shrouds (now on the other side) should be equally slack.
If, however, you don’t like this look, when you get safely back to the dock or at anchor, you can tighten the shrouds 1-2 turns equally on both sides. Take a look to see that the mast is still straight and plumb.
