 C25 battery advice sought
JV
Initially Posted - 08/24/2005 :  19:46:31  Show Profile
The time has come to replace the battery on my '83. I don't have electric start and just run the lights and radios from it. I have shore power and motor charging. I'm often out 2-4 days with little motor charging if any. I'd like a battery that can survive heeling and rough conditions. Would a gell battery work well for this? My old battery weighs a ton but I since it is mounted low and nearly centered I doubt this is a great concern. Any advice on an appropriate C25 battery would be welcome. Thanks.
1983 TR FK #3436--"Joint Venture" Flathead Lake, MT
Response Posted - 08/24/2005 :  20:40:29  Show Profile  Visit Leon Sisson's Homepage
JV,
Since you say you're often out for two to four days without shore power or much motoring to recharge, I'd suggest a group-27 or larger battery.
Gel-cells are low (no) maintenance, work at any angle, and I seem to remember that they're forgiving of deep discharge cycles. The disadvantages are high initial cost, and sensitivity to charging regimen. (Easily overcooked.)
For the best value, I'd suggest flooded cell deep cycle. Either a 12V group-27, or a pair of 6V golf cart batteries in series. Keep in mind that flooded cell batteries are particularly unforgiving of being left in a discharged state. Even discharging them below 50% causes some degree of damage and reduced service life. It would be best for flooded cells to be mounted inside acid proof battery boxes.
Which ever type you go with, be sure it's well restrained, protected from accidental short circuits and from physical impact by other heavy stuff shifting around nearby.
JV
Response Posted - 08/24/2005 :  22:18:15  Show Profile
Thanks for the advice. I'll see what I can find.
Bill Holcomb
Response Posted - 08/25/2005 :  09:32:39  Show Profile
Hi JV
If you decide to get a gel-cell battery instead of a new lead-acid flooded battery, remember that the gel-cell battery charges at a lower voltage than the flooded battery you have been using. You will want to change the setting on your charger to the gel-cell setting. If you don't, you'll probably severly damage or destroy the new battery.
On Snickerdoodle I have two group 24 flooded batteries. They both fit nicely in the battery compartment at the aft end of the starboard settee.
JV
Response Posted - 08/25/2005 :  11:03:19  Show Profile
Good advice Bill. I may avoid the gell-cells just for that reason. And my charging systems are not adjustable. I also remembered that I may add an auto helm in the future and the twin 24's would help with that larger draw.
JimB517
Response Posted - 08/25/2005 :  11:39:34  Show Profile  Visit JimB517's Homepage
I have two group 24 size gell batteries. They have been relocated into battery boxes under the quarterberth. They are 55 amp hours each.
I love these batteries. No acid, no maintenance. They will run the boat for about 2 weeks of day sailing or 2 or 3 days of overnightingwithout being concerned about charging.
I have a Guest 3 amp shore power charger which charges them up usually in a couple of hours. I don't leave the trickle charger running (no need - I use the boat nearly every day).
I have a voltage regulator that keeps charging voltage below 14.1 volts.
Dave Laux
Response Posted - 08/25/2005 :  20:04:59  Show Profile
Just back from 6 weeks of living totally on the boat. Minimum engine running. About an hour and one half in four days for example. We use a single grp 24 battery and have never been unable to start the outboard. Most of the stuff on the boat draws so little power that I do not know how long one battery will last. I would go with less battery rather than more until it was proven not to work. Especially since all of our engines will hand start.
We have depth finder, log, GPS, autopiot, second depth finder, anchor light , reading lights, running and deck light rarely used. Dave
Stu Jackson C34
Response Posted - 08/26/2005 :  14:44:00  Show Profile
Everyone uses their boat differently and had different equipment, so it's important to do an Energy Budget. Figure out how much you need and size your battery bank accordingly. Also, if you'd like to stay out longer without charging, then more IS better.
JV
Response Posted - 08/26/2005 :  16:24:54  Show Profile
Thanks for all the advice. I like the idea of gells but don't want to risk frying them. I'll try to get another trip out of the old one and then decide.
ronrryan
Response Posted - 08/27/2005 :  11:51:34  Show Profile
Orion has two 24 deep cycle (so-called) wet cells in the stbd locker, I considered two golf carts, but they tend to be a bit taller and I didnt think they would fit. I have no outboard charger, just shore power at the dock thru a three stage marine charger, works for me, but then I am not on the hook or without shore power for extended periods, would have solar panels if on a mooring, Fair winds, ron Orion SR SK in SWFL
Buzz Maring
Response Posted - 08/27/2005 :  12:38:47  Show Profile
<font color="blue">Orion has two 24 deep cycle (so-called) wet cells in the stbd locker, <u>I considered two golf carts</u>, but they tend to be a bit taller and I didnt think they would fit ... - Ron</font id="blue">
I know what you meant, Ron ... but, that still cracks me up!
Scooter
Response Posted - 08/28/2005 :  10:29:46  Show Profile
I need to replace my battery and am thinking of a gell. We had one on our 22 O'Day and it served us well. We didn't, however, have an alternator on our outboard.
This boat has an alternator on our 9.9 Johnson.
Question: Will this alternator charge the Gell? What kind of regulator would work? Would I have to "fool" the regulator?
I know some of the pros and cons of Gell, non Gell, Golf cart batt, etc... I like the Gell tolerance to long shelf life over winter, and lower discharge tolerances etc...
Any Gell stories out there? For now just looking for Gell stories. No need to "sell" us on other options for now. Just want to see what others have done for Gells.
thanks.
ronrryan
Response Posted - 08/29/2005 :  15:53:32  Show Profile
I was hoping that with the golf carts deployed and at full RPM I would gain at least half a knot. Oh well....Ron Orion srsk SW FL
John V.
Response Posted - 09/04/2005 :  15:01:39  Show Profile  Visit John V.'s Homepage
I doesn't matter what kind of battery you have if you have no way to make a significant amount of power. a solar panel that produces a minimum of 2-5 amps will keep your batteries up if you have minimal use. On Nin Bimash we are out for weeks at a time and rarely "plug in" at a marina. My solution was an air-x wind generator. depending on the wind speed it will produce from 5-30 amps. With two depth sounders, auto pilot, chart plotter, and vhf radio, our power usage is perhaps a bit more intense than the average sailor. wind power is free and continues throughout the night and on cloudy days. On Nin Bimash we have two 115 AH deep cycle trolling motor batteries. Both are 4 years old and still are working fine. I don't remove them in the winter, just charge them up and give them a litte boost every month or so.
Buzz Maring
Response Posted - 09/04/2005 :  18:01:48  Show Profile
<font color="blue">... My solution was an air-x wind generator. depending on the wind speed it will produce from 5-30 amps ... - John </font id="blue">
Hi John,
You're the only one of us I'm aware of who uses a wind generator ... I've often wondered why more C-25/250 owners don't have them ... is it because of expense? 'Lack of space for mounting the unit? 'Something else?
Where/how did you mount your generator? Do you by chance have any photos?
Thanks!
John V.
Response Posted - 09/04/2005 :  20:47:52  Show Profile  Visit John V.'s Homepage
Hi Buzz,
The Air-X is mounted on a 9' galvanized steam pipe. nice and rugged. the whole works is inserted into a mount built into the port stern corner. a three ft. pipe with the same ID as the tower's OD so the two slide together. The mount pipe goes through the deck and is bolted to the gas shelf and is bolted to the deck through a plate welded to the deck pipe. I took all the parts to the place where the Ohio dept of transportation galvanizes guard rails. once dipped they were coated with epoxy appliance paint.
The first pic gives you a view of the whole rig and the second gives a view of the base. I used #8 wire to connect to the carging panel. from there I can controll which battery is being charged. There is a charge/stop switch that can shut the turbine off it the charging is done. So for example if I sail on bat 1 I have bat 2 on the turbine and the next day I switch. It works pretty well.
Photo credit: Karen Larson ed. Good Old Boat Magazine
Edited by - John V. on 09/04/2005 21:05:08
Buzz Maring
Response Posted - 09/05/2005 :  11:06:11  Show Profile
WOW John ... that is some impressive setup!
Thanks for the explanation and photos. I've saved all of your info for my "sailboat files" in case I ever want to install a system like that. If I ever get to retire, and if gas doesn't rise to $5 a gallon, and a lot of other "ifs," someday I'd like to be able to trailer my boat to different parts of the country for extended sailing adventures ... your wind generator would be a great piece of equipment to have aboard.
There are several boats owned by our Association members that I'd love to see in person one of these days ... yours is definitely one of them! You've really maintained her well, and you've done some fantastic mods, too.
Thanks again for the help.
Edit: BTW John ... I noticed that you gave credit for the photos to "Good Old Boat" magazine ... did they do a story on you & your boat? If so, what issue?
Edited by - Buzz Maring on 09/05/2005 17:01:30
John V.
Response Posted - 09/05/2005 :  17:54:32  Show Profile  Visit John V.'s Homepage
Hey Buzz, The photos are by Karen Larson who is the editor of Good Old Boat. I had spent the previous evening on board she and her husband Jerry's C&C 30 sharing my local knowledge of the North Channel. (and some of Karen's killer beer bread) They have moved their boat into Lake Huron for the next two years. The photos were taken shortly after I tossed a baggie full of Hot blueberry muffins over to them. The practice makes for great friendships. She emailed the pic's to me about two weeks ago.
Edited by - John V. on 09/05/2005 17:56:10
Buzz Maring
Response Posted - 09/05/2005 :  18:05:39  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by John V.</i>
<br />Hey Buzz, The photos are by Karen Larson who is the editor of Good Old Boat. I had spent the previous evening on board she and her husband Jerry's C&C 30 sharing my local knowledge of the North Channel. (and some of Karen's killer beer bread) They have moved their boat into Lake Huron for the next two years. The photos were taken shortly after I tossed a baggie full of Hot blueberry muffins over to them. The practice makes for great friendships. She emailed the pic's to me about two weeks ago.
COOL STORY!
seastream
Response Posted - 09/05/2005 :  21:00:42  Show Profile  Visit seastream's Homepage
John:
Who makes that 100 HP engine on the stern of your boat?
Bob
John V.
Response Posted - 09/06/2005 :  12:03:46  Show Profile  Visit John V.'s Homepage
The motor is a honda 100....100cc rated at 9.9 hp. I believe it is an 84 model. There is in a lot of marketing schemes a desire to make things seem bigger by adding zeros. hence the Catalina 250 (a 25 ft boat) who knows why....
I mean how would you get 100 hp into that little package and who is fooled.
