 Making an A-frame for a C22
Kas
Initially Posted - 08/30/2005 :  09:13:20  Show Profile
Hello All...
I was talking to a C22 owner who was new to sailing and was having trouble raising his mast. I told him about the A-frame system that we used and he was really interested. Does anybody know what modifications would have to be made to use it on a C22 if any? Or maybe someone has a link to that kind of information. Thanks
Kelly
Adventurous #5553
1987 C25 SR/SK2WK
Turk
Response Posted - 08/30/2005 :  19:12:14  Show Profile  Visit Turk's Homepage
Here are detailed pictures of a mast raising system I made for my Cat 22 last winter. Aluminum frame that fits into a foot and a half stainless pipe that is mounted on each base on each side. Easily raise and lower single handed. Very stable. Uses block and main sheet to raise.
Turk
http://www.elmhurstprop.com/kitty/mastraise/
Edited by - Turk on 08/31/2005 06:56:34
Response Posted - 08/31/2005 :  09:09:39  Show Profile
Perhaps this will help
[url="http://www.stewartfam.net/arlyn/mrs.html"]The Standing A Frame[/url]
JimB517
Response Posted - 08/31/2005 :  11:15:55  Show Profile  Visit JimB517's Homepage
I made a conventional A frame with parts from Home Depot for under $10. I used steel electrical conduit and a couple of bolts. The pipes were easily bent to shape and drilled. They bolt to the forward lower bases and must be free to rotate 90 degrees. There is an eyebolt at the A. A line to the main winch clips on this and runs through a block at the pulpit. The Jib halyard also clips to this. The jib halyard is tied off at the base of the mast.
It works, winch it up and down. Under $10. Make it in an hour.
I made my mast crutch with 1.5 inch PVC and it was too weak. But I slid the PVC into a aluminum tube I had laying around and that works great. I just tie the crutch to the stern pulpit or set it on the dock. If you have helpers you don't even need it.
Kas
Response Posted - 08/31/2005 :  13:24:47  Show Profile
Thank You for your suggestions...
I'll report back with the results soon!
osmepneo
Response Posted - 08/31/2005 :  15:25:33  Show Profile
Raising the mast on my 22' was fairly simple without using an A-frame:
1. Position the mast over the transome with the top of the mast pointing aft.
2. Place the bottom of the mast in the tabernacle.
3, Fasten Make sure the back stay and forward shrouds are fastened. and the aft shrouds and forestay are clear of any kind of entanglement.
4. Place the mast on your shoulder and walk forward, stepping up onto the cabin top, until the mast is in place.
5. Fasten the forestay and both aft shrouds.
I did this by myself, using the jib halyard as a temporary forestay, fastening it on the bow pulpit. It was quite easy to do this with two people.
Hope this helps.
mfasis
Response Posted - 09/26/2005 :  09:42:06  Show Profile
<br />Perhaps this will help
Arlyn,
I really like this design. How long should the legs be?
