 Question about a battery
Ben
Initially Posted - 09/02/2005 :  07:15:28  Show Profile
Hi all,
This is not about a sailboat, but rather about a bass boat. My dad's actually. He and I spent a long time yesterday working on his boat, which hadn't been used in over a year. His cranking battery is only a year and a half old, but it won't hold a charge. We have this fancy-dancy battery charger that tells you what percent full the charge is as it charges. When we put the charger on it reads around 60%, and within five minutes it is charged. The charger is set to a 10amp/30amp charge. (There is no way to separate the two.) Anyway, we take the charger off, then put it on five minutes later and the charge is back down to about 60%. Of course the engine starts fine at full charge, but after a few starts the battery runs out of juice. Is it just a bad battery?
The engine is a Johnson 9.9 hp, very similar to the Johnson Sailmasters that many of us have used. There is no pull start either, and has worked for years and years with electric start and no problems.
Thanks folks!
Ben
Beneteau 361
Viking Kitty
Columbus, Ohio
Response Posted - 09/02/2005 :  07:43:25  Show Profile
Since the battery sat for so long, I would guess that it has sulfation on the plates and is toast.
Response Posted - 09/02/2005 :  12:48:38  Show Profile  Visit aeckhart's Homepage
I concur.
JimB517
Response Posted - 09/02/2005 :  14:29:01  Show Profile  Visit JimB517's Homepage
Go to Pep Boys and buy a $5 specific gravity meter, this measures the fluid in the cells. The fluid is very strong sulfuric acid so be careful. The meter looks like a turkey baster, you pull up a sample of the juice.
But even without this I can tell you have a bad cell. All cells should test nearly the same specific gravity. One is bad - sulfer crystals have grown all the way across the lead plates shorting them.
Time for a new battery.
