I am on a budget and like to do my own work whenever possible. I picked up a bolt of sunbrella and would like to re-make my sailcovers and other Sunbrella items.
However, my old sewing machine doesn't like more than 2 layers of the new Sunbrella fabric, which really limits what I can do. it is an old, metal cased "Imperial" machine. We also have a Singer around, but it is plastic and I am sure not able to do any better.
Anyone out there with personal experience who can recommend an AFFORDABLE machine that will sew multi-layers of thick fabric? If I knew of brands or models that would work, I could start a search to find one used....on E-bay, or at sewing centers or wherever else you might suggest.
Thanks. I have saved a TON of money in the past doing my own work, and I recommend it for those with the equipment who are willing to "risk" a bit.
Sewing doesn't threaten my masculinity. It is just another type of "construction" as I see it, just using different tools and materials.
A cheap heavy duty machine is an oxy-moron. You could take the thickest thing you want to sew to a sewing center. Try it out on the different machines. I have a 1970's era Reads Sailmaker. It will sew through bones and is still worth what my dad paid for it 25+years ago.
I am no expert but think you should look at a walking foot machine as it will feed normally when sewing ultra heavy materials.
Most of the heavy duty machines are made in Japan ot Tawain. They are all about the same in construction. Sailrite has several models to choose from. Don't be affraid to spend some cash on this as you will still make out in the long run. And, if you decide to sell, it will retain most of it's value.
<center> Cheapskate Apprentice Seamsters Club </center> Somewhere, I think it was SailRite, I found a list of desirable features for a boat canvas duty sewing machine. The criteria I can recall include: <ul> <li>Metal good, plastic bad. Especially the moving parts such as gears.</li> <li>External motor good, internal bad. It's important to be able to easily replace the motor, perhaps with a more powerful one.</li> <li>Heavy flywheel good. I've even read about adding stick-on car wheel ballancing weights to improve flywheel inertia.</li> <li>High lift pressure foot adjustable over a wide range of pressure.</li> <li>Walking foot good. Lots of luck finding an inexpensive one though.</li> <li>Long, high arm good. That is what determines how wide a project you can sew in the middle of. What's important is the total area of the tightest point under the arm. Think genoa or spinnaker repair.</li> <li>Cabinet good. I like the ones about the size of a small table that also store the machine and a few accessories inside when not in use. This is also where your knee-activated speed control mounts.</li> <li>I prefer a mechanical sewing machine, not a computer. I'd try to get one with as few electronic features as possible.</li> <li>Company still in business, new parts still available.</li> <li>Accepts industry standard everything. Bobbins, thread spools, needles, light bulb, belt, motor mount, whatever.</li> </ul> I found an old Brother 'Project' model at a garage sale for under $100. It looks like it has never been used. I can punch through all the layers of Sunbrella where overlapping hems are folded over each other at corners. It does at least a dozen fancy embroidery stiches using interchangable mechanical cams. It's not walking foot, and could use a more powerful motor, but over all, I'm rather pleased.
I used it to make a foredeck bag for our jib. It worked well and my friends who have a sailrite machine said it looked the same as theirs except for the color. I was able to sew through several layers of sunbrella and nylon webbing that I used to reinforce stress points. It's a fraction of the cost of the sailrite, which I know is a very good machine.
I picked up a old Pfaff 130 on ebay for around $175 then had it worked over by the Pfaff dealer in Spokane, WA cost for the was $100 but included a improved flywheel and had crank mechanism that can be used inplace of the electric motor. Works great for sails, sunbrella. I have even used it for nylon strapping. Sews straight and zig-zag. It was recommended to me as a good machine for this kind of work by John Neal.
The Sailrite does look like a knockoff type machine. The main advantage of the sailrite is someone who speak english to talk to when you have a problem. They claim it is tuned by sairite and has special stuff. Call around to the local repair shops and ask them for a tough machine. Then bring your fabric and let er rip. My machine goes through everything without binding, grinding or banging. I fully expect to give it to one of my kids one day.
Be careful with the "bargain" as you may be greatly dissapointed and will still have to pay someone to mend sails etc. You might be able to find a partner or 2 for shared use. Or even mend a few sails to recoup the cost.
Another brand that is bulletproof is consew. Really great machines.
When we got married the first appliance we purchased was a Pfaff Hobbymatic 917. With it we did quite a few sewing projects on the Hobie Cat. Even sewed new hiking straps to the vinyl trampoline! As much as my wife liked the machine when we bought our big boat it needed all new cushions and foam. We bought a Sailrite machine, figuring it will pay for itself with the money we save on the cushions. My wife loves it and the cushions turned out great. Now I see her choose the Sailrite for all the home projects and the Pfaff is just for lighter weight stuff, even though it is a lot less trouble to lug out of the closet. My wife did say she wants to buy the big flywheel but we have not yet.
Regarding men and sewing: I don't see any association with the skills and any particular sex but in my household I have realized that my wife had already invested a lot of hours in building skills and that if I let her do my projects they turn out much better. Also she is much better at visualizing things turned inside out than I am. As an architect I make my living visualizing 3 dimensional constructions but turning them inside out eludes me. I used to argue with her about how to construct things, now I just say "Show me". I have increased one sewing skill in my partnership, I have become adept at ripping out mistakes.
This is all helpful information and I appreciate it. However, several of you have said that you own "the Sailrite model". Well, they sell at least 6 different machines, from the Apprentice, which they say will sew 6 layers of Sunbrella but has no walking foot, up to the "Professional Sailmaker" or something that is over $2000.
It would be helpful to know if anyone has the $350 Apprentice model, and whether or not it gets recommendations. It might take awhile to make a $700 investment pay off, if half that amount would buy a machine that would do the job.
I have a Necchi I bought from some distributer for about $250. It isn't especially heavy duty, but I've made hand rail covers, tiller cover, sail cover and bimini using sunbrella. At one point on the bimini I know I was sewing atleast 5 layers. I had intended to take it in to a upholsterer for that seem, but was able to do it on my machine (slowly).
Bottom line: unless you are going to do an awful lot of sewing, lighter machines can be used. Make some test stitches with many layers of fabric. That was what sold me when they demoed my machine to me.
Gary, When faced with the same dilemma two years ago, I dropped in to the university upholstery shop to ask the pros. Pfaff is the high mark. To show off, they actually sewed through a piece of 1/4" plywood. They make tool holders out of thick leather, canvas awnings, etc. Their advise: get a Pfaff (German made), with a walking foot, zigzag, and reverse. A local upholstery supply outfit has a contact with an industrial sewing machine repairman who sells used machines. He had a few Pfaffs, but I just couldn't justify the purchase price. Went to EBay looking for Industrial Sewing Machines and found a new MORSE for $250 (?). I have cranked out new main sail cover, sock for furling head sail, sleeves for life line cushions, bug screens for companionway/front hatch, tiller handle cover, anchor riding sail, anchor chain sock, etc. I am constantly adjusting tension on the Morse. I keep thinking I should have gone with the Pfaff. My .02. Something like this:
Another thought is to call a loft and see what they use.
Most sailmakers would be glad to offer you their advice. You may even get lucky and find a loft that has an old machine they are trying to get rid of. dw
Gary, I found an old White machine. All metal and as I read the list of positive features that Leon has, it comes out pretty darned good. $69 at the local sewing machine shop. This guy sells new machines and takes trade-in's. I have sewn a dodger, thru window material and sunbrella. Be sure to keep a sharp needle and regularly oil the gears. As for the walking foot being expensive. This same shop sold me a very simple attachment for less the $20. I have sure gotten my moneys worth out of this old machine and the best thing is I don't get yelled at for asking to use the wife's super duper machine.
Well I might go ahead and throw in my 2 cents. I bought my wife a sewing machine with an eye towards cusions and biminis and what-not. We were steered towards a White brand "Jeans Machine," which is specifically designed for denim and thicker fabrics. My wife loves it. :)
I think it was about $240 or thereabouts and we got it at Hancock Fabrics. Our first project was recovering an old sofa we got at the thrift store. We did it all in denim and courderoy. Came out very nicely (for our first upholstry project) although next time we'll make thicker cushious. ;)
My mother owns a fabric/sewing store and she gave me this little tid-bit when I asked her why I was having so much difficultly sewing through thick material: Use a rounded point needle rather than a super sharp pointed one (I forget the size) -- makes a huge difference.
Check this machine out. It looks like it would sew through anything. I have had dealings with Harbor Freight and the customer service has always been perfect. Even when a truck ran over my utility trailer. They sent me the parts for free because it had a lifetime warantee.
Does not say anything about a walking presser foot. That is one of the nice attributes of a heavy duty machine from Sailrite and others. A walking foot moves with the bottom feed to pull the fabric through the machine together.
