 Trailer compatibility
Esteban
Initially Posted - 11/05/2005 :  20:20:00  Show Profile
Folks,
Would anyone know by chance if a trailer for a 79' Oday 23 swing keel would work with a Catalina 25 swing keel? Possible modifications to make it work?
Esteban
Esteban Diaz
Tally Ho!
atgep
Response Posted - 11/05/2005 :  20:44:00  Show Profile
It would seem that the oday23 would be a lot lighter. Perhaps 2 oday trailers would be what you need.
Tom.
Response Posted - 11/05/2005 :  21:17:19  Show Profile  Visit Frank Hopper's Homepage
It is generally agreed that the two 3500lb axles normally found on a Catalina trailer are bear minimum if not undersized. If it has dual 3500lbs axles you can get by, any less and you should not try it.
