 Mast Pad Eye Location
Initially Posted - 05/03/2002 :  17:32:34  Show Profile  Visit aeckhart's Homepage
OK, so I'm new at this chat room business! I assume that there is no fixed location for the spinnaker mast pad eye. If however I use your suggestion and let the sail "hang" than place the eye where the pole is level, I would have a problem with the pole clearing the stantion (sp?) lines since the pole will only be used with a cruising spinnaker or 150 genny. I assume than that the pole eye should be mounted just high enough so that the pole will clear the stantions.
Al Eckhart
5801 Gallivant
<b></b>
Edited by - aeckhart on 05/07/2002 11:50:53
eric.werkowitz
Response Posted - 05/03/2002 :  17:49:05  Show Profile
For what it is worth, Catalina's blue print for the mast shows a fixed whisker pole padeye on the front of the mast 5' 0'' up from the bottom. For a spinaker, it has 1" aluminum track 56 1/2" long centered on the front of the mast with the highest point 6' from the bottom. Obviously, it's a one or the other installation.
Eric Werkowitz
C25 #4969
Edited by - eric.werkowitz on 05/07/2002 21:05:00
Response Posted - 05/03/2002 :  18:38:40  Show Profile
Me, Tarzan...you, Jane?
Don Lucier, Northstar
C25 SR/FK
Response Posted - 05/03/2002 :  18:41:13  Show Profile
Me got wine, you got cheese?
Derek
Response Posted - 05/06/2002 :  07:57:57  Show Profile  Visit Champipple's Homepage
Warum in der Hölle jeder ist, wie Tarzan, oder ein früher Fernsehcharakter(Fernsehbuchstabe) aufgestellt sprechend, um ein heimischer Indianer zu sein. Ich würde vorschlagen, den paddeye, ungefähr sechs Fuß von der Plattform zu setzen. Wenn der padeye für einen spinaker Pfosten oder Barthaar-Pfosten ist, konnten Sie es finden, besser eine Schiebespur mit einem Auto zu kaufen.
Duane Wolff
"The Flying Wasp"
C-25, #401 std,sk
Chief Measurer C-25/250 national Org.
<img src="http://im1.shutterfly.com/procserv/47b2dc20b3127cce9cd2f45b211a0000004010" border=0>
Response Posted - 05/06/2002 :  09:25:19  Show Profile
Kazuntite
Response Posted - 05/06/2002 :  16:41:03  Show Profile  Visit Champipple's Homepage
loosley translated as:
Why in the hell is everyone speaking like Tarzan, or some early television character posed to be a native American indian.
I would suggest putting the paddeye, about six feet from the deck. (but try putting a sail up first. you want the pole to be parrallel to the water.) If the padeye is for a spinaker pole or whisker pole, you might find it better to buy a sliding track with a car.
Duane Wolff
"The Flying Wasp"
C-25, #401 std,sk
Duane Wolff
"The Flying Wasp"
C-25, #401 std,sk
Rick Heaverly 86 C25 5382
Belize
Response Posted - 05/07/2002 :  01:54:55  Show Profile
install the pad eye chest high. or chest high for your crew member (admiral)or whoever will be working the foredeck. if it's too high the admiral might not be able connect the pole.
Rick Heaverly
Response Posted - 05/07/2002 :  10:21:09  Show Profile
Duane has the right idea. The pole needs to be horizontal when deployed. Hoist the headsail, attach the outboard end of the pole and hold the pole in the "working" position (choose a light air day to do this!) - then mark the mast at the point at which the pole is horizontal. Install padeye at this point. Ce n'est pas difficile, oui Duane!
Derek on "This Side Up"
John Mason
Response Posted - 05/07/2002 :  14:34:36  Show Profile
Why bother? A cruising (asymetrical) spinaker doesn't use a pole. So the padeye/pole (whisker pole) would only be used for the genny in downwind mode...which you have a cruising spinaker for. Simple is better.
John Mason - Ali Paroosa
1982 - FK/SR #3290
Brooke Willson
Response Posted - 05/08/2002 :  15:28:40  Show Profile
It depends on what you consider simple: $ 300 for a whisker pole (Catalina Direct) or $ 700 to $ 1000 for a cruising spinnaker.
Brooke
