My '01 250 which I just bought had no antenna installed. I understand I can install a starboard rail mount antenna, less expensive than a masthead one. Once installed, how do I lead the wires to the radio unit below (I have an ICOM from my old boat) and to the battery in the aft compartment? Or should I just use the bucks to buy a handheld? 5 watts vs. 25 watts, right? I sail offshore Southern California.
You will get much better transmission and reception with the antenna mounted on the mast head, due to the height difference. But if you elect to go with the rail mount version, you can run the cable through the hull, along the existing wire conduit in the starboard side of the boat, to the area near the wiring panel. If you take the wiring panel off the wall, and look inside, you should see the end of the wiring conduit (mine is grey, about 3/4" dia.). If you crawl into the aft section of the boat (where the steering gear is located), you will see the other end of the wiring conduit (high up, riding on the deck level, starboard side).
Sorry I don't have any pictures. And my boat and trailer are now under snow. I carry a handheld as a back up.
So a rail mount antenna for a 25 watt ICOM would only have a slightly longer range than a 5 watt handheld? If so, the handheld and my cell phone should be sufficient for our local waters. I don't have any "steering gear"; I'm a tiller dude.
