The cowling latch on my new Tohatsu 9.8 has no place to secure the link or the bungee. If anyone's acquainted with this excellent engine and has a soft link attached...how did you do it? Gracias, mi amigos.
I have a Nissan 5hp but had a similar problem. I just drilled 2 holes in the upper cover above the latch and added a small brass loop fastened with two bolts and nuts. Works fine.
The spring holds the lever that locks the engine in the up position down at all times. Without the spring you have to reach back over the motor and push the lever down once you get the motor up to insure a positive lock. With the spring you just pull the motor up and the engine raises the lever until it drops into the lock position due to the spring. Hopes this helps. If not maybe I can explain another way.
I picked mine up at Target. It is brass plated and made to go on one of those small travel ironing boards to hold the cover on. I just took it apart and made two just incase I messed up one. It is not very large and doesn't have a great deal of pull, but enough for what I wanted do accomplish.
Did not want to spend a lot of money for a try out so it did not matter, fifty cents was the right price. I will start looking for something better now that I know it works. I am not to sure if stainless would be cost effective or if they are available. I'm sure you can get anything for the right price, somwhere.
As I was walking through Homey Depot this AM and passed the bungee section, the light bulb did illuminate and Aryln's favorite spring did pop in to mine and the small 18 inch ones should work prefect. I will be changing my soft link bungee tommorrow so I will also change the spring at the same time.
P.S.: The spring ONLY relieves you of ONE reach-down: securing the engine after it's pulled up. To put it down, secure it, and bring it up, you still have to reach down and activate the lever.
Frank, I don't understand the many reach downs? I only have one reach down and that is to pull the lever up and release the motor to the down position. To get the motor up and locked I just pull up the motor and it lifts the lever and the bungee pulls the lever down to the locked position when the motor is full up.
How do you lock the lever when the engine is down? It has to be locked when the prop's turning in forward gear. If so locked, only way to unlock it is to reach down.
There is no locking requirement in forward gear. The engine thrust at the prop keeps the engine down while under way and if you happen to hit a log or anything else, you want the engine to pop up To lessen the chance of lower unit damage. As opposed to reverse where you need the motor locked down so the prop does not pull the engine out of the water when you give it incresed throttle.
Frank, There are 2 locks for the engine. The one that keeps it down in reverse and neutral is linked to the gearshift. The lock Jerry put the spring on is only for tilting.
