 Swing Keel Bolt Size.
sodonnell
Initially Posted - 01/21/2006 :  23:46:13  Show Profile
I'm planning on dropping my swing keel in a couple of days to inspect it and prep it for the season.
I'm planning to use a method of lowering the keel that I found through this web site which includes replacing the bolts with long threaded rods.
Does anyone know the standard size of the bolts holding the swing keel? The boat is far enough away that I don't want to make the trip just to check.
Scott
ct95949
Aruba
Response Posted - 01/22/2006 :  09:48:51  Show Profile
Hi Scott
It's a 3/8" bolt-pretty sure it's 1-1/4" long.I used 316 stainless with a lock washer then coated with 3M 4200 to keep the water away from the threads.As an option the keel can be lowered and replaced pretty easy with a good sized floor jack on a concrete slab and I would guess a lot quicker than the all thread method.Good luck.
HudsonM1
Response Posted - 01/22/2006 :  09:49:02  Show Profile
Hi Scott.
I was looking for similar info. According to this sting, it could be 3/8.
http://www.catalina25-250.org/forum/topic.asp?TOPIC_ID=10031&SearchTerms=threaded,rod
Hudson
Response Posted - 01/22/2006 :  10:05:49  Show Profile  Visit Leon Sisson's Homepage
The four C-25 swing keel pivot support bolts are 3/8-NC thread.
steephen
Response Posted - 02/05/2006 :  16:38:42  Show Profile
It's pretty easy to block up the keel in a horizontal position and lower it slowly with the house jack; this does away with the need for threaded rods, which I used the first time. I replaced the pin, bushing blocks, bolts, cable and cable holder all at once; let us know if you have questions.
Stephen Z sailing "Little Wing"
