 Rigging tension
stewendkos
Initially Posted - 02/07/2006 :  12:21:11  Show Profile
I recently had a rigger adj.the standing rig.He had no specs.to go by,and it looked like a generic thing,although he did use a gauge.I,being more or less a perfectionist,called the Cat.factory and they faxed me the specs.They were as follows:back-32,fore-24,upper-35,lower20.I bought a gauge and they all measured 34.
The rigger was a very experienced (well known)person and has sailed extensively.I hate to loosen the stays; are they that critical? I'm interested in knowing what method you use in determining the tension.Do I really need the gauge or can I just eye-ball it.I understand about the mast rake,I'm really just interested in the tension.
Steve
Steve Wendkos
My Doll #692 Gone!
Edited by - stewendkos on 02/07/2006 12:28:05
Capt. Kurt
Response Posted - 02/07/2006 :  13:09:15  Show Profile
You might want to read the following thread on subject.
[url="http://www.catalina25-250.org/forum/topic.asp?TOPIC_ID=9042&SearchTerms=LOOS"]Loos PT-1[/url]
An overtight rig may put unnecessary stress on the rigging components.
Kurt
#818 C250WK 'Tortuga'
Edited by - Capt. Kurt on 02/07/2006 13:14:08
stewendkos
Response Posted - 02/07/2006 :  21:51:32  Show Profile
Thank you for the response.Lots of variations,but I'll work through them.
AADIVER
Response Posted - 02/07/2006 :  23:19:05  Show Profile  Visit AADIVER's Homepage
Steve, what do those numbers represent? If your backstay is 34 and Catalina recommends 32, do you tighten or loosen to get 32? I assume lower numbers are looser, higher numbers tighter. Or...?
Turk
Response Posted - 02/08/2006 :  02:56:48  Show Profile  Visit Turk's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Capt. Kurt</i>
<br />You might want to read the following thread on subject.
Kurt
Corrected link (new web site):
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=9042&SearchTerms=LOOS
JohnMD
Response Posted - 02/08/2006 :  08:04:03  Show Profile
I also found the tensioning rather confusing. Some points I did notice, however. There are two Loos gauges that are being used, the Model A and the PT1. They give different readings when used. Make sure you know what Loos gauge a person is using when they tell you what the tensions are. The numbers from Catalina are for a Model A. Using a conversion chart, the same numbers for a Loos PT1 are upper 25, lower 16, and rear 23. I set my wires to these tensions using a Loos PT1. I later found that, when close hauled in a 10 knot breeze, this wasn't enough tension to keep from having slack in the leward shrouds. I made slight adjustments equally to both sides until the slack disappeared. As I understand, you want just enough tension on the wires to keep the slack out, NO MORE. That's my two cents, probably about what it's worth. By the way, before I adjusted my wires, they were way, way over tightened. I, however, haven't noticed any difference in the way the boat sails. Good Luck.
jking
Response Posted - 02/08/2006 :  09:33:51  Show Profile
What size Loos gauge fits the 250? Apparently, there are different sizes to fit different diameter rigging.
John King
JohnMD
Response Posted - 02/08/2006 :  11:12:49  Show Profile
Go read the link above. Not all 250's have the same diameter wires.
Response Posted - 02/08/2006 :  12:38:34  Show Profile  Visit Frank Hopper's Homepage
and not all wind conditions warrant the same tensions, I would trust your rigger.
