 small leak
southern cross
Initially Posted - 02/23/2006 :  15:43:49  Show Profile
I just got back from my 1982 c-25 at the marina installing the brand new cushions (i will post photos very soon) and I noticed a small amount of water in the quarter berth area. This was strange because I have been lucky to have never had any leaks. I traced the source back to what I think is the problem. If you are laying on your back in the quarter berth looking back towards the front of the cabin and you look up there are two small wooden boards (for lack of a better term) they are screwed in and mine look like they are what is allowing the water in. The pieces of wood are water stained and warped. I think I will take them out and cut some new plastic templates. I was thinking of taking them and sealing the edges and putting them back in place instead of the pieces of wood. The question that I had was what is above these hatches. I thought it was the interior sides of the rubrails but I looked and I do not think that it was it is. I believe it is just an area underneath the turnbuckles, winches, cleats etc. and behind the coaming boxces in the cockpit Should I think about re-bedding these to keep the water from being there in the first place. I believe I cab easily stop the leaking into the quarter berth but if I do where will the water go? Maybe the bilge, if so I can handle that, the bilge pump will do it's duty. One thing I didn't know is if any water in this area would go to the bilge or just continue to collect and then leak from somewhere else.
Any knowledge would be exremely appreciated
Pura Vida
Zach
southern cross 1982 C-25
TR FK #2867
Buzz Maring
Response Posted - 02/23/2006 :  15:52:29  Show Profile
Hi Zach,
I think the most likely source(s) to leak water into the area where you're seeing it would be a winch, cam or clam cleats (or whatever you have there to take care of your sheets), and any cockpit instrument(s) you have mounted on the starboard bulkhead in the cockpit.
'Hope that helps ... good luck finding/fixing the leak!
southern cross
Response Posted - 02/23/2006 :  15:59:20  Show Profile
Thnks Buzz. That was what I was thinking. Short have having to re-bed anything if I fix the are in the cabin that is letting the water in do you think the water will end up in the bilge so that the pump can get rid of it?
JimB517
Response Posted - 02/23/2006 :  18:04:22  Show Profile  Visit JimB517's Homepage
Don't feel bad, all our boats have deck leaks and on some the fight can seem endless. Those boards are there so you can get at the underside of the winches and and deck hardware you have like the stern pulpit, stern light, etc. Pull the boards off and look up in there with a flashlight. You'll see there is plywood on the underside of the deck. The plywood will be rotted and mushy where the leak is. My stern light has a leak.
Don't seal the boards and screw them back in, that would just make it worse.
Buzz Maring
Response Posted - 02/23/2006 :  18:11:31  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by southern cross</i>
<br />Thnks Buzz. That was what I was thinking. Short have having to re-bed anything if I fix the are in the cabin that is letting the water in do you think the water will end up in the bilge so that the pump can get rid of it?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Hi Zach,
Frankly, I'd fix the leak.
I dearly love these old boats, but the reality is, most of them have lots of rain leaks by now. It is no fun to track them down and fix them, but, IMHO, we should all strive to keep a dry bilge. The more moisture that stays in the boat, the more likely you'll end up with mildew that'll trash your boat and make it stink. Also, if your boat ever develops a leak that could sink it, you'll never know you've got a leak if the bilge is full of rain water.
You could remove the wooden panels and try to pinpoint the source of the water while someone sprays the outside with a garden hose. If the winch and/or clam/cam cleats are letting in water, rebedding them isn't hard to do. If the water is leaking in from around instruments mounted in the bulkhead, that might be a little more difficult to rebed, but still relatively easy.
'Hope that helps, even though it might not be what you wanted to hear. Not fixing the leak would be kinda' like wetting the bed ... 'a short term solution to a long term problem ... sooner or later you've got to get up and do something about it.
southern cross
Response Posted - 02/23/2006 :  18:39:12  Show Profile
Thnks guys, I get it now. Get off my lazy a$% and fix the leak itself. That's what I thought I would. I just need a kick from time to time.
Pura Vida
Zach
