 Aft hull thickness question:
AADIVER
Initially Posted - 03/07/2006 :  00:18:48  Show Profile  Visit AADIVER's Homepage
How thick is the hull of my '01 250 just to the port side of my aft battery? Single layer fibreglass or foam sandwich? Can a depth transducer be set there and get an accurate reading?
Frank Farmer
Long Beach, CA
aa.diver@verizon.net
http://mysite.verizon.net/aa.diver
PRETTY PENNY
'01 C-250 WK, Hull #558
frog0911
Response Posted - 03/07/2006 :  07:57:51  Show Profile
Frank, the hull on the 250 is 5/8" thick of glass. There is no foam in the hull. I mounted my transducer forward of the keel also. I wanted to know the depth before I hit anything to give me a fighting chance of avoiding it if I was quick enough. Knowing the depth after I smack ground was kind of like closing the barn door after the horse got out.
AADIVER
Response Posted - 03/07/2006 :  08:25:45  Show Profile  Visit AADIVER's Homepage
Thanks, Frog. I'm pretty well locked into mounting the 'ducer in the stern based on where I want my unit placed, and direct connect to the battery. I don't anticipate sailing in shallow water out here on the Left Coast
kevinmac
Response Posted - 03/07/2006 :  09:35:28  Show Profile
Frank,
If you do mount the transducer there, you will need to fair it to get it to point straight down, or it will lose some accuracy.
Also, I don't know why, but everything I've read says that depth transducers need to be mounted forward of the keel on sailboats. The turbulence from the keel messes up transom area mounts. I think you are talking about a through the hull (no hole) transducer, so you could try it, see how it does, with no risk.
FWIW.
Edited by - kevinmac on 03/07/2006 09:37:47
AADIVER
Response Posted - 03/07/2006 :  10:59:19  Show Profile  Visit AADIVER's Homepage
All I need is "ballpark" accuracy, i.e. depth primarily and bottom contour. Fish I could care less about. For 90 bucks delivered it's the most cost effective depth sounder I could find online.
Response Posted - 03/07/2006 :  12:06:34  Show Profile  Visit britinusa's Homepage
Similar topic,
anyone know the thickness of the area around the windows?
We're putting up curtain tracks that are going to be screwed in place, don't want to have screw points sticking outside around or in the window plastic.
I have 1/2" SS screws that will penetrate about 3/8ths. Risky?
TIA.
Paul.
Buzz Maring
Response Posted - 03/07/2006 :  12:28:03  Show Profile
<br />Similar topic,
TIA.
Paul.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Hi Paul,
Would you please send me an email? I haven't been able to reach you through this Forum, or at your regular email address ... I think maybe your spam filter is blocking me.
Please email me at buzzmaring at AOL dot com ... thanks!
bear
Response Posted - 03/07/2006 :  12:43:20  Show Profile
I believe "Oscar" had a tech tip on this subject.
Tom Potter
Response Posted - 03/07/2006 :  17:03:49  Show Profile
Paul,
I followed Oscars tech tip on the curtain install and it worked great.
Frank,
Keep us posted on your transducer mounting. The good thing about the wax is if it don't work in one spot its easy to move to another.
