 drop leaf table
SEAN
Initially Posted - 03/15/2006 :  16:10:05  Show Profile
Here is a table I made
we moved the backrest back a foot so we can lay down watching tv (lifes good)
I tryed to find matching material to do the cushions but no luck .I called catalina and some upholstery places .
http://im1.shutterfly.com/procserv/47b6dd35b3127cce9794dd85f60300000016100BYt2rRo1Ysc
http://im1.shutterfly.com/procserv/47b6dd35b3127cce9794dd8a773c00000016100BYt2rRo1Ysc
http://im1.shutterfly.com/procserv/47b6dd35b3127cce9794d22b370200000016100BYt2rRo1Ysc
http://im1.shutterfly.com/procserv/47b6dd34b3127cce9790fc412fca00000016100BYt2rRo1Ysc
http://im1.shutterfly.com/procserv/47b6dd34b3127cce9790fc02aeb900000016100BYt2rRo1Ysc
http://im1.shutterfly.com/procserv/47b6dd34b3127cce9790fc00aebb00000016100BYt2rRo1Ysc
Tradewind
Response Posted - 03/15/2006 :  17:02:23  Show Profile
Thanks for the pics, gives me some ideas. I need to replace my big table.
Russ.Johnson
Commodore
Response Posted - 03/15/2006 :  17:11:57  Show Profile
Sean, On your previous post you asked how to post pictures.
Check out the Testing Forum [url="http://www.catalina-capri-25s.org/forum/forum.asp?FORUM_ID=1"]Testing Forum[/url]
Also the FAQ page is handy [url="http://www.catalina-capri-25s.org/forum/faq.asp"]FAQ [/url]
I couldn't do it until a read these posts.
Here are your pictures again.
Russ (#793)
Edited by - Russ.Johnson on 03/15/2006 17:21:43
Tom Potter
Response Posted - 03/15/2006 :  18:23:39  Show Profile
Sean,
I noticed in a couple of your pictures you have those small stick on lights, over your galley and in your V-berth. What do you think about them? How long do they last on a set of batterys?
frog0911
Response Posted - 03/15/2006 :  18:42:51  Show Profile
Sean, what kind of jig, if any, did you make to allow for the straight cuts on your table?
SEAN
Response Posted - 03/15/2006 :  18:47:11  Show Profile
not very long ,But they are cheap and I put them all over,
under the sink is the best help .I have one on both sides of the rear berth those look great when you sit at the table.Were on a moring so saveing the volts is nice.
I velcroed them to the ceiling so their easy to move.
also the light is not real bright perfect for me sets the mood nice.
SEAN
Response Posted - 03/15/2006 :  18:55:16  Show Profile
I started with a sheet of marine plywood
(better glue I`m told)
you have to cut the leafs first . I think the center is 12"
(so you can use the support piece from the old table)
Then slide the three pieces together and trace the old table on the wood.I jig sawed it and sanded.
Edited by - SEAN on 03/17/2006 08:22:21
Tom Potter
Response Posted - 03/15/2006 :  19:06:55  Show Profile
Sean, looking at the front of your table, looks like it lends a place where you could install a drawer. Any storage area on the 250 is good
Response Posted - 03/15/2006 :  19:19:36  Show Profile
Very nice table!
Turk
Response Posted - 03/16/2006 :  04:02:46  Show Profile  Visit Turk's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by SEAN</i>
<br />you have to cut the leafs first . I think the center is 12"
Can you show us the underside and how it hinges and is supported?
frog0911
Response Posted - 03/16/2006 :  13:22:25  Show Profile
Sean, my apologies, the table is a perfect match for the orginial so I thought you just cut the orginial. Well done!!!!!!
SEAN
Response Posted - 03/17/2006 :  08:18:33  Show Profile
The orginial looks like formica.I thought it might chip if I cut it.Plus you would have a raw edge to match when its folded down.
I always prefur changes you could go back to orginial (in case you like the old way better after its done)
AADIVER
Response Posted - 03/17/2006 :  16:49:22  Show Profile  Visit AADIVER's Homepage
Sound decision, Sean. The original table stores right under the V berth cushions. I'm going the marine ply route without the drop leaves; just going to make the table narrower for ease of access to the V. I'm a simple guy so I gonna make a simple table
Edited by - AADIVER on 03/17/2006 19:08:56
SEAN
Response Posted - 03/17/2006 :  18:10:13  Show Profile
here are some pics underneath
