 Douglas
Initially Posted - 03/23/2006 :  06:42:22  Show Profile  Visit Champipple's Homepage
Are they lifting that with the strap on the Keel….That doesn’t seem right, or stable
D. Wolff
DPO C25 Hull 401
Currently Sailing "Champagne and Ripple" 1982 O'day 30
Chief Measurer 2002-2006
Vice-commodore 2007
Edited by - Champipple on 03/23/2006 11:36:08
Response Posted - 03/23/2006 :  07:27:46  Show Profile
Why wouldn't it be stable? Aren't all full keelers, like Island Packets, lifted by the keel?
Response Posted - 03/23/2006 :  11:39:18  Show Profile  Visit Champipple's Homepage
I've never seen it done that way, that's why I asked. Usually the straps are put in line with the bulkheads on either side of the keel. The keel is generally centerline, your not really supporting the aft end of the boat and your point of contact and support is singular using the keel method above. You are in contact with more surface area the other way.
djn
Response Posted - 03/23/2006 :  12:48:02  Show Profile
I don't know this boat, but if it is a full keel, won't lifting it under the keel be the only way to lift it? Just a thought. Cheers.
existentialsailor
Response Posted - 03/23/2006 :  13:58:52  Show Profile
To add another view, Capri's are meant to be lifted by the keel but from within the cabin.
Response Posted - 03/23/2006 :  14:53:15  Show Profile  Visit Champipple's Homepage
Rick,
The small racers are amazing with respect to launching boats. It makes the c25’s and 250’s and anyone else look like amateurs. Most of the ones I’ve seen are J22’, Stars and J24’s. They all dry sail (no need to paint bottom to slow them down, and they don’t get waterlogged either) and within a 40 minute period I’ve seen over 20 boats launch from 2 hoists. It is a very neat setup on all of those boats – plus the center of gravity remains below where the load is carried.
In reference to the Alberg:
Maybe so, but I have never seen that. Especially on a 29 footer. The straps in my experience on any boat have always been in relation to the bulkheads
I could see a number of additional things with that
1- puts way more stress on the keel in an environment where it can rock and sway – Cracking along the seem (also referred to as the Catalina smile)
2- center of gravity is way way higher
I might be wrong, that is why I asked – it doesn’t seem right to me though.
Response Posted - 03/23/2006 :  15:09:34  Show Profile
I think Dennis is right. It's a full keel boat. The Alberg's keel extends all the way aft, almost to the transom, and the rudder is attached to the aft end of the keel. The aft lifting strap has to rest on the keel. On our boats, the fin keel ends 2-3 feet aft of the center of the boat, and from that point back to the transom, the strap can wrap directly around the hull.
Edited by - Steve Milby on 03/23/2006 15:14:51
John G-
Response Posted - 03/23/2006 :  16:18:48  Show Profile  Visit John G-'s Homepage
<font size="2"> <font face="Comic Sans MS">
I have watched our yard pick up a few full keel boats and that’s what it looks like. They spend quite a bit of time on the first few inches off the cradle.
Man! Is that a gorgeous boat or what?
Hey Douglas how do I get her to [url="http://www.obmc.com/once%20in%20the%20harbor.htm"]Oyster Bay[/url]?
Underlined words are a <b><font color="red">HOT</font id="red"></b> link.
Go ahead click on the bird.
</font id="size2"> </font id="Comic Sans MS">
Response Posted - 03/23/2006 :  16:30:59  Show Profile  Visit Champipple's Homepage
Never actually saw them do a full keel boat like that, the full keel part must have been the disconnect. It makes a bit more sense now
Sea Trac
Vanuatu
Response Posted - 03/23/2006 :  16:49:25  Show Profile
<br />The Alberg's keel extends all the way aft, almost to the transom, and the rudder is attached to the aft end of the keel.
Same as an Allied 32' Seawind MkII.
Douglas
Response Posted - 03/24/2006 :  18:46:54  Show Profile  Visit Douglas's Homepage
I know what you mean. The forward strap can slide forward and drop the boat. If you could see it from the side you would see the straps are lashed together to prevent them from spreading.
